Author Topic: Locks on Super Six plus 2 English Mark Dart game  (Read 3113 times)
JRLMCL04
  • Last login:March 15, 2013, 12:51:13 pm
  • I'm smiling.... that alone should scare you!
« on: March 14, 2013, 01:58:14 pm »
Hello everyone,
So I own a Super Six plus II English Mark Dart game and I only have one key which is to the coin mech/change bin. The problem I have is there is a new issue with the wiring where it failed a few of the tests and I need to get into it.
Does anyone know if there is a trick to picking the lock? or maybe removing it without some major cutting?
Thanks for the help!
Jeff
Jeff
JRLMCL04
Re: Locks on Super Six plus 2 English Mark Dart game
« Reply #1 on: March 14, 2013, 04:56:44 pm »
ALSO on this same Dart board I had a small screen flicker that came and went. I've checked the wiring and replaced the fuse "just to be sure" and haven't seen the flicker since....
anyone know of any "known" issues or fixes to this?
Thanks everyone for the help.
Jeff
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 14, 2013, 11:14:13 pm »
The tilt down front panel and the back door are National Cabinet Lock key # C-415A. Some jukeboxes also use this key number.
Here is where you can buy the key that will open your machine:
http://www.needles4jukeboxes.com/rowe_keys.htm
Just scroll down the page most of the way and you'll see it.
JRLMCL04
« Reply #3 on: March 15, 2013, 12:34:18 pm »
Ummmmmmm yeah Ken I suppose your right! what a novel approach.... get a key..... HA!
MUCH appreciated!
Jeff
