Author Topic: Mala refresh main game list issues  (Read 2783 times)
wetwaterwalker
  • Last login:June 06, 2014, 02:28:20 am
  • First Time Mamer
« on: March 13, 2013, 08:09:33 pm »
Hello all,
      I recently updated my Roms to v148 and tried to sort them with rom lister. I got a decent list that I liked but when I put the xml file into my mala configuration, Mala locks up every time I try to refresh the game list. Am I doing something wrong? Need some screen shots? It works fine when I just let Mala great the xml file. Thanks!
wetwaterwalker
  • First Time Mamer
Re: Mala refresh main game list issues
« Reply #1 on: March 13, 2013, 10:00:59 pm »
I figured out my problem.
Dekieon
  • Last login:January 07, 2025, 03:17:55 pm
« Reply #2 on: March 15, 2013, 01:44:00 am »
You should put in the solution to your problem in the thread.
In the future, someone may be looking for a solution to a similar issue and may find your thread via a search. So it is good practice to always put the solution to your issue in the thread when you figure it out on your own.
wetwaterwalker
  • First Time Mamer
« Reply #3 on: March 18, 2013, 01:35:24 am »
Sorry I hadn't been on here in a few days.
The problem turned out to be user error on my part.  What I was doing was after i generated the list, when Romlister asked to generate an xml file, it asked what format to make it in. I ended up selecting the wrong front end from the list. Therefore when I was trying to run it in mala it was causing it to crash.
