Author Topic: New Cabinet Purchase - thoughts?  (Read 1141 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: March 12, 2013, 11:06:01 am »
I have a seller who is willing to sell me a newly made cabinet.  The cabinet does not have a coin door cut out...is this something that I can do even though it's already assembled?  Just curious as I'm thinking that the cabinet might not have enough strength during the cut out of the coin door from template.
Mental
  • Last login:May 18, 2013, 09:46:08 am
    • Complete cocktail arcade system
Re: New Cabinet Purchase - thoughts?
« Reply #1 on: March 12, 2013, 11:38:18 am »
What is the cabinet made from? I don't think you should have any issues, depending on the tool you use.
Also, most coin doors have a good overlap, so the cleanness of your cut isn't too important.
« Last Edit: March 12, 2013, 09:25:21 pm by Mental »
Complete cocktail arcade system: arcadecabinets.ca
  • Last login:Today at 12:17:33 pm
« Reply #2 on: March 12, 2013, 12:47:51 pm »
Yes, you can cut a hole for a coin door.
No, it will not weaken the structure of the cabinet.
As long as you don't scratch up the finish or damage already-installed electronics (if any) you should be fine.
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #3 on: March 12, 2013, 06:09:51 pm »
If it is already painted, mask off the area with painters tape  ;D
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #4 on: March 12, 2013, 06:43:36 pm »
as long as you have room for one there`s no problem, I bought a "multi tool" saw/sander (see pic) for £30 from argos (on sale) which i used to cut the hole for my switches,bezel,coin door,used it to trim the plexi for my marquee and also cut some pieces while holding them in my hand, as long as your careful it`ll cut exactly where you point it, hardly any pressure needed, and did it after I`d built the main cab, very useful :)
Hit something hard enough it should work, if it dont the result can always be called art :)
