Author Topic: Determining which version of roms  (Read 2222 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: March 05, 2013, 08:09:32 am »
Is there a tool that can determine which version a rom is based upon the zip?
Hoopz
  • Intellivision Rocks!
Re: Determining which version of roms
« Reply #1 on: March 08, 2013, 04:17:17 pm »
Easy/Quick answer:  No.
Complicated way to try:  Using Clrmamepro, you can take whatever set you have but you have to then convert it to another set using rollback roms or the newest version of Mame and a .dat file.  So you go through the effort of acquiring a new version and then converting the files you have to a new/old version.
You won't know what version you had, but you will know what version you end up with.  Not a perfect solution but it works and it's one way to give you a specific version of roms albeit it's somewhat of a hassle.
If you have an idea of what version it is, you can use Clrmamepro with a .dat file for that suspected version to check the roms and report and issues/missing roms.  That's more of a hunt and peck method though.
Bottom line:  The best answer is no.
iscariot
« Reply #2 on: March 27, 2013, 01:04:30 pm »
Thanks.  An extension of that....is there a way to see when a certain game was first supported in MAME?
  • Last login:Yesterday at 07:46:44 pm
« Reply #3 on: March 27, 2013, 03:55:59 pm »
Short answer... "sort of"
The catver.ini can tell you when a game was first ADDED to mame.  Of course it can take years before they get a game working, so that isn't as useful as it sounds.
iscariot
« Reply #4 on: April 01, 2013, 01:17:25 pm »
Ok then...maybe this is outside the scope of this board, but is there somewhere in the actual mame binary that I could find the version information?   I've got a "closed" version of it w/o source.
spoot
  • Destroyer of electronics
« Reply #5 on: April 19, 2013, 04:52:23 pm »
Not that I'm aware of....but wouldn't be too hard to develop an app to do so....but not bored enough atm to do it.   :P
« Reply #6 on: April 19, 2013, 08:41:07 pm »
Sorry man, but it would be rather hard to impossible to do so.   The only way to determine the approximate version a rom works with would be to compare it to a -listxml output of every single version of mame.  Even then, you'd have a rom that works on several versions of mame, not just one.  So yeah, it's technically possible to do, but highly improbable.
Now you can determine if a particular rom will work on YOUR version of mame, but guess what?  That's what mame's -verify option and the various rom managers out there already do.  ;)
