Author Topic: Tube Reguveination? or something else  (Read 2238 times)
BC_Jeffro
  • Last login:March 09, 2020, 04:55:23 pm
  • you can never leave the game!
« on: February 28, 2013, 10:38:54 pm »
I got 2 WGK7000 monitors yesterday so i threw a test rig together and tested them one is all blue and the other is all green i have adjusted both and they are both missing colors
i caped one and no change at all
« Last Edit: March 01, 2013, 12:38:41 am by BC_Jeffro »
  • Last login:Yesterday at 07:25:33 pm
Re: Tube Reguveination? or something else
« Reply #1 on: March 01, 2013, 01:37:55 am »
swap the neck boards, does the weird color follow the board?
if so, you have a bad transistor or amp on the neckboard and must replace it.
swap the transistors around, does the colors change?
if so, the transisor is bad
if not, the amp is bad LM1203? i belive.
BC_Jeffro
« Reply #2 on: March 03, 2013, 12:10:49 am »
swapped neck boards and no change on either
buffett
  • Last login:December 13, 2016, 01:28:10 am
« Reply #3 on: March 06, 2013, 07:33:47 am »
re-flow the video input header.
check all the transistors in the color circuit.
two for each color on the main chassis near the video input header and one for each color on the neck board.
also check to see if the pots on the neck board are not broken.
i would get the tube checked just so you know if it needs any help or not.
and if all else fails i can repair them for you if you want to send them in.
check out my YouTube channel to see what it do.
https://www.youtube.com/user/buffett1978?feature=mhee
Peace
Buffett
« Last Edit: March 06, 2013, 07:38:58 am by buffett »
Come to MAGfest and game in the 24-7 arcade for 4 days. www.magfest.org  And see my collection of 90+ Arcades and growing.
Need your (K7000, 4900, std/med res 13"-25") or Sanyo fixed!!!! pm me.
Visit my website. www.thearcadebuffett.com For Monitor and PCB repairs.
Fully rebuilt chassis ready to ship. Trade'ins welcome
I have met --- Tim McVey --- world nibbler champion and many of you have not.
« Reply #4 on: March 06, 2013, 09:57:54 pm »
when you say no change when you swap the neck boards
do you mean:
you swapped the "green looking" board to the other monitor and it's still "green looking"
or
you swapped the "green looking" board to the other monitor and it's now "blue looking"
BC_Jeffro
« Reply #5 on: March 08, 2013, 12:20:22 am »
the green tube stayed  green and the blue tube blue
buffett
« Reply #6 on: March 08, 2013, 04:48:25 am »
you may need to get the tubes checked.
this sounds like some of the guns are shorted.
or possibly the neck transistors may be bad.
swap each chassis to the opposite tube and check that as well.
this will help tell us if it could be a tube problem or a chassis problem.
either way the chassis need a rebuild.
cap kit. flyback and re-flow of the chassis and neck board.
Peace
Buffett
BC_Jeffro
« Reply #7 on: March 20, 2013, 09:32:21 pm »
i swaped chassis and the color did not change on the tube the geen stayed green...
« Reply #8 on: March 20, 2013, 09:40:06 pm »
i would say the gun is toast. if you have some repair places near you call a few of them up and ask if they have a tube tester.
you may rejuvenate it, but be warned, rejuvenation may last a year, a month, a day, an hour. it's completely random. it may last forever.
buffett
« Reply #9 on: March 21, 2013, 06:03:45 am »
try a rejuve first if you can find a shop or local collector that has a tester.
i rejuve allot of tubes with great success.
Peace
Buffett
