Author Topic: GroovyArcade live-CD 2020  (Read 650436 times)
  • Last login:Yesterday at 05:56:31 pm
Re: GroovyArcade live-CD New Release 2016
« Reply #640 on: February 10, 2017, 03:26:25 pm »
thanks for the advice. with AMD APU 15KHz is possible ?
is there any website to check that kind of stuffs ?
It's a matter of testing. But testing costs money. That's why it was suggested to grab a common supported ATI card in the first place. I can't remember of anyone using and APU on Linux yet. But if the chipset is supported by the open source driver, you can bet it'll work for 15 kHz.
SpaceGod
  • Last login:June 03, 2025, 10:44:22 am
« Reply #641 on: February 20, 2017, 08:05:02 pm »
its funny i was going to try to mod the crtemudriver to work with older nvidia cards before seen this thread :notworthy:
SpaceGod
« Reply #642 on: February 24, 2017, 12:23:53 am »
i have been having problems with the gui and the frontend  not displaying 15khz im using a hd6970
edomatic
  • Last login:October 24, 2024, 04:01:22 pm
« Reply #643 on: February 24, 2017, 03:07:45 am »
Hi guys,
I have installed this groovy arcade lice cd to disk but now i am wondering how to update the groovymame version to the latest version?
Can someone tell me how to do this?
thanks
SpaceGod
« Reply #644 on: February 24, 2017, 10:15:30 pm »
im problems ive fased for far(most of them i think are because of my gpu hd6970)
  • the  frontends and gui dont  run correctly use arcade monitor (i tried 320240)
  • my arcade sticks dont work on the groovy mame after using rejoystick if i tried to map rt button it would map then mess up the keyboard and mouse
2huwman
  • Last login:August 16, 2025, 06:01:13 pm
« Reply #645 on: February 28, 2017, 01:38:27 pm »
Hi guys,
thanks
I'm having the same issue - the update site seems to be down so i haven't been able to update my version of groovymame. is there another way of doing this?
« Reply #646 on: February 28, 2017, 04:43:20 pm »
You'll have to download the updated binary and install it manually.
With regards to the 6970, it should work fine, provided you target the right output in the boot kernel line.
With regards to controls not working, etc., yeah, I'm afraid that's a Linux feature. Basically with Linux, you're on your own. If you're experienced enough to know how to deal with problems when they happen (and they will) then you're lucky and it's your system. Otherwise, better try Windows, where controls just work, etc. We envisioned a sort of plug-and-play distro that would be easier to get working than Windows, but unfortunately the world is too complex for that to work without a full-time-dedicated team behind.
b4nd1t0
  • Last login:February 11, 2025, 01:35:18 am
    • b4nd1t0's repository
« Reply #647 on: March 01, 2017, 02:58:13 am »
I'm not a great expert but I've always replaced the mame executable and recreated the mame.ini. everything has always worked.
Inviato dal mio XT1032 utilizzando Tapatalk
2huwman
« Reply #648 on: March 01, 2017, 03:57:36 am »
Thanks - I've managed to do that withearlier versions of groovymame - just unpack the groovymame bz2 file in usr/games/bin (i think that's what is was) and it worked. However, on newer versions it unpacks, but then mame won't load. maybe something to do with permissions? i'll have a look.
EDIT: I've changed the permissions so they match the version of groovymame that does work, but it still won't load. Any other suggestions or ideas please?
« Last Edit: March 01, 2017, 04:22:05 am by 2huwman »
b4nd1t0
« Reply #649 on: March 01, 2017, 06:26:35 am »
I tried right now with 0183, after updating QT5 to the 5.8.3 version (the new mame needs this) and did the update with sudo pacman -Syuu everything works. the executable groovymame should be put in / usr / local / bin and mame.ini after you create should be moved in / home / arcade
« Last Edit: March 01, 2017, 06:31:03 am by b4nd1t0 »
Doozer
  • Z80 ERROR
« Reply #650 on: March 01, 2017, 07:34:35 am »
Yes you are right. The version from the google drive is created with a fully updated groovyarcade distribution (or Arch Linux).
If you need to check the required library version you can use the command "ldd groovymame".
Here is the output for a NON updated OS version:
$ ldd groovymame
./groovymame: /lib64/libQt5Core.so.5: version `Qt_5.8' not found (required by ./groovymame)
        linux-vdso.so.1 (0x00007fff2b89e000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f4c0bd9c000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f4c0bb94000)
        libSDL2-2.0.so.0 => /lib64/libSDL2-2.0.so.0 (0x00007f4c0b87d000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f4c0b65f000)
        libutil.so.1 => /lib64/libutil.so.1 (0x00007f4c0b45c000)
        libGL.so.1 => /lib64/libGL.so.1 (0x00007f4c0b1ce000)
        libasound.so.2 => /lib64/libasound.so.2 (0x00007f4c0aed9000)
        libQt5Widgets.so.5 => /lib64/libQt5Widgets.so.5 (0x00007f4c0a874000)
        libQt5Gui.so.5 => /lib64/libQt5Gui.so.5 (0x00007f4c0a3d1000)
        libQt5Core.so.5 => /lib64/libQt5Core.so.5 (0x00007f4c09f47000)
        libX11.so.6 => /lib64/libX11.so.6 (0x00007f4c09c08000)
        libXinerama.so.1 => /lib64/libXinerama.so.1 (0x00007f4c09a03000)
        libSDL2_ttf-2.0.so.0 => /lib64/libSDL2_ttf-2.0.so.0 (0x00007f4c097fb000)
        libXrandr.so.2 => /lib64/libXrandr.so.2 (0x00007f4c095f0000)
        libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007f4c093ac000)
        libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007f4c09101000)
        libdrm.so.2 => /lib64/libdrm.so.2 (0x00007f4c08ef0000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f4c08b66000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f4c0885d000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f4c08646000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f4c08280000)
        /lib64/ld-linux-x86-64.so.2 (0x00005620462f8000)
        libGLX.so.0 => /lib64/libGLX.so.0 (0x00007f4c0804f000)
        libXext.so.6 => /lib64/libXext.so.6 (0x00007f4c07e3d000)
        libGLdispatch.so.0 => /lib64/libGLdispatch.so.0 (0x00007f4c07b85000)
        libharfbuzz.so.0 => /lib64/libharfbuzz.so.0 (0x00007f4c07921000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f4c0770b000)
        libpng16.so.16 => /lib64/libpng16.so.16 (0x00007f4c074d8000)
        libicui18n.so.57 => /lib64/libicui18n.so.57 (0x00007f4c07060000)
        libicuuc.so.57 => /lib64/libicuuc.so.57 (0x00007f4c06cb7000)
        libicudata.so.57 => /lib64/libicudata.so.57 (0x00007f4c05238000)
        libpcre16.so.0 => /lib64/libpcre16.so.0 (0x00007f4c04fcf000)
        libgthread-2.0.so.0 => /lib64/libgthread-2.0.so.0 (0x00007f4c04dcd000)
        libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007f4c04aba000)
        libsystemd.so.0 => /lib64/libsystemd.so.0 (0x00007f4c04a2f000)
        libxcb.so.1 => /lib64/libxcb.so.1 (0x00007f4c04807000)
        libXrender.so.1 => /lib64/libXrender.so.1 (0x00007f4c045fb000)
        libexpat.so.1 => /lib64/libexpat.so.1 (0x00007f4c043d1000)
        libbz2.so.1 => /lib64/libbz2.so.1 (0x00007f4c041c1000)
        libgraphite2.so.3 => /lib64/libgraphite2.so.3 (0x00007f4c03f95000)
        libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f4c03d22000)
        libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f4c03b05000)
        libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f4c038de000)
        libcap.so.2 => /lib64/libcap.so.2 (0x00007f4c036d9000)
        liblzma.so.5 => /lib64/liblzma.so.5 (0x00007f4c034b3000)
        liblz4.so.1 => /lib64/liblz4.so.1 (0x00007f4c0329f000)
        libgcrypt.so.20 => /lib64/libgcrypt.so.20 (0x00007f4c02fb9000)
        libgpg-error.so.0 => /lib64/libgpg-error.so.0 (0x00007f4c02da3000)
        libXau.so.6 => /lib64/libXau.so.6 (0x00007f4c02b9f000)
SpaceGod
« Reply #651 on: March 01, 2017, 05:22:38 pm »
Thanks for the repond i havent tested frather through because of homework but i think just some libraries need to updated . If im correct mame on linux uses some open source HID library for input (Xorg i think)
2huwman
« Reply #652 on: March 02, 2017, 03:32:31 pm »
Thanks - I updated as suggested, and groovymame worked straight away at 15khz! But then when i restarted the system, advancmenuplus loaded OK, but then groovymame did not output a 15khz signal anymore  ???
Is the GroovyArcade-Arch2016.07.02-x86_64 ISO the most recent update? I thought there was a newer one with the Attractmode bug fixed, but can't find it.
b4nd1t0
« Reply #653 on: March 03, 2017, 06:04:54 am »
Try substituting again the executable mame, perhaps the upgrade has replaced your mame with the normal version. However to use normally attract mode you can set in the Configure/Miscellaneous options "Enable multi monitors to NO and Window mode to Full Screen Mode", it worked for me. Unfortunately, what you have is the latest version of groovyarcade and if you want to upgrade it needs a bit of adjustments, but is always great  ;)
2huwman
« Reply #654 on: March 03, 2017, 08:55:14 am »
Thanks very much - I'll try that fix for Attractmode!
2huwman
« Reply #655 on: March 28, 2017, 04:34:48 pm »
Attractmode working great now, and updateed to MAME 178!
But I can't figure out how to set up high scores  :banghead:
I've got the plugins folder from the windows release. Can anyone share their mame.ini and plugins.ini please, along with where the plugins folder is supposed to be! Thanks very much.
b4nd1t0
« Reply #656 on: March 31, 2017, 03:25:04 am »
The plugin folder is the same, put it in /home/arcade/, in mame.ini you need to activate the plugins (usually is already active)
# CORE MISC OPTIONS
plugins                   1
in the same place you need the file plugin.ini, in this file you need to activate the hiscore
# PLUGINS OPTIONS
hiscore                   1
the default is 0
the folder "hi" is present by default, here the file will be created for each game
PhoneGuy
  • Last login:June 02, 2020, 01:34:56 pm
  • Crazy
« Reply #657 on: April 25, 2017, 09:42:05 pm »
I'm upgrading the PC in my 13 years old mame cabinet and am having trouble with GA.  I've got a WG D9200 monitor and a Arcadevga 5000 that's replacing the original AVGA.  I know I would be better off with just a regular compatible ATI card with Groovymame and Switchres but at the time I ordered the AVGA 5000 I was planning to recreate what I already had.  I used GroovyArcade live-CD Release 2016 64bit on a usb stick to do the HD installation to an SSD. I had various issues after trying to immediately update to groovymame .184.  I wiped the SSD and reinstalled GA with gm .171.  and am just testing with the included roms.  I find Attract-Mode and Wahcade both hang when exiting from a game.  Based on earlier posts this seems to have been a past problem at least for Attract-Mode.  Any fix for this?
I seem to have a DISPLAY setting issue if I drop to the shell from gasetup and try to run groovymame "/usr/local/bin/groovymame -v alienar" I get "Can't open display" errors and a segmentation fault. See attached alienar.txt for full output. Attract-Mode from the commandline core dumps with a "Failed to open X11 display; make sure the DISPLAY environment variable is set correctly" message.  Wahcade from the commandline core dumps with a long list of display errors. How do I run these from the command line?
If I do upgrade with "pacman -Syyu" so that gm .184 will run (QT5 lib error otherwise) will that break output to my D9200?  It seemed to but I could have changed some other setting. After bios messages there was no signal to the D9200.
ves
  • Last login:April 11, 2020, 02:57:49 am
Re: GroovyArcade live-CD New Release 2017
« Reply #658 on: May 01, 2017, 02:13:09 am »
New version 2017.
In the root / ati folder, there is driver for vga, if you have problems install the different versions to check.  "pacman -U driver-name"
Attractmode is not tested, report faults or new configurations.
Now X starts with openbox for multi-resolution, Thanks Doozer.
GroovyMame 184 and Fix Hiscore
« Last Edit: May 01, 2017, 02:38:34 am by ves »
b4nd1t0
« Reply #659 on: May 01, 2017, 03:50:23 am »
Great news! Thanks ves and all the others who contributed.
ves
« Reply #660 on: May 01, 2017, 05:52:38 am »
I've found a bug when you start the first time, cursor stays on the screen only, you have to focus with the mouse or close X and enter again.
b4nd1t0
« Reply #661 on: May 02, 2017, 06:32:09 am »
I was doing some test with the new release and I noticed a remarkably worst performance, for example, wrally with the previous release run at 100% now goes to 69/70%, I also tried to replace the groovymame version with the previous 171 and it does not change. What has determined this deterioration of performance? I'm testing them on a virtual machine, not on real hardware.
ves
« Reply #662 on: May 02, 2017, 04:58:57 pm »
Virtual box does not support framebuffer right now, I have not installed the driver.
b4nd1t0
« Reply #663 on: May 04, 2017, 05:19:37 am »
Thanks, then I will continue testing on real hardware
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #664 on: May 04, 2017, 12:48:33 pm »
this is awesome. Thank you for all the work.
I am a bit behind.. Can you prevent people from exiting the front end?
My kids hold the Player One Start and hit Button #1 to exit a game and if they do it more than once it registers as multiple esc key hits which exits the frontend to the setup menu... Then they scream daaaaaaddddd. Daaaaadddd its not working.
To be fair adults at parties do the same thing.
Ok thank you guys again for all the hard work!
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
« Reply #665 on: May 05, 2017, 06:00:57 am »
Re-configure the front-end to ignore the ESC key.
linux4eva
  • Last login:May 10, 2017, 11:36:45 am
« Reply #666 on: May 08, 2017, 03:43:59 pm »
I'm having problems with 2017 Groovy Arcade image.
Both booting live from USB and using HDD installation I'm running into the same problem:
the CLI and games work fine on Sony Trinitron SCART TV using self made VGA2SCART adapter, but every frontend does not support 15khz.
When frontend loads I can swap cables for LCD monitor and the picture is showing. I have tried setting different custom resolutions for Xorg/frontend though gasetup CLI. The video card is ATI HD7790 using DVI-I 1 port through VGA adapter.
P.S. the link to the manual on the googlecode site is broken.
EDIT: OK I've read the topic a bit further and see that you are aware that wiki is destroyed by google.
I've solved my problem. The thing that helped me is that xrandr command output was "Can't open display" and that confirmed that Xorg video driver is not set up.
I have edited xorg.conf:
Maybe the only thing that was necessary was to change the output.
« Last Edit: May 09, 2017, 02:17:18 pm by linux4eva »
PhoneGuy
  • Crazy
« Reply #667 on: May 09, 2017, 10:39:27 pm »
After not having much luck with GroovyArcade live-CD Release 2016 a few weeks ago I tried the new  GroovyArcade live-CD Release 2017.  I found Attract-Mode and Wahcade both no longer hang when exiting from a game which is an improvement. However I have found a new problem.  The mouse control does not work correctly for me.  For example if I launch Missile Command or Centipede, mouse control seems limited to a small square.  I can use the keyboard to move the cursor to a different area of the screen and the small box of mouse control is around this new location.  I downloaded the 184 and 185 executables from the google drive location and replaced GA version of the groovymame executable in /usr/local/bin with each of these to test.  If I use advance menu plus to launch Centipede or Missile Command they have proper mouse control.  However Attract mode will launch the game but it locks up as the initial screen is displayed.  I have to ctrl-alt-F2 to another terminal and kill groovymame to get out of the game.  I also tried editing the .xinitrc replacing the frontend on the last line with "groovymame centiped3". Now gasetup would launch directly to into centipede with the same results in that the ga version of groovymame did not have proper mouse control while the google drive versions 184 and 185 do.  If Attractmode would work with either of these executables I would be in decent shape.
ves
« Reply #668 on: May 13, 2017, 03:02:18 am »
Jtslade
misc_exit
Selects the exit mode.
misc_exit none | normal | shutdown | all
Options:
   none    Exit is disabled.
   normal    Exit is possible pressing ESC.
   shutdown    Exit is possible pressing CTRL-ESC.
   all    All the exit modes are possible.
linux4eva
Do you select 15khz dvi option from boot menu?
If you do not select right option, script does not work to configure.
PhoneGuy
We know that problem, you need to use groovymame version no wiimote.
PhoneGuy
  • Crazy
« Reply #669 on: May 13, 2017, 02:23:42 pm »
PhoneGuy
Where do I get this? I didn't see it on the GroovyArcade or Groovymame/UME google drive locations unless it's the older groovymame64_0171.015m_wiimote_linux.tar.bz2 release.
Doozer
  • Z80 ERROR
« Reply #670 on: May 14, 2017, 05:46:11 am »
PhoneGuy
Hi PhoneGuy,
I will provide a build including no Xinput dependency (aka wiimote). Give it a try and check if it solves your issue.
PhoneGuy
  • Crazy
« Reply #671 on: May 14, 2017, 09:57:02 am »
Hi PhoneGuy,
I will give it a try once you post it.  Is this different than 184 version you have on google drive now?  It does not include "lightgun_index1  WiiMote0" settings and it works for me other than it locks up if launched with Attract-Mode.  No mouse issues and Wahcade and AdvanceMenuPlus launch it fine.
Doozer
  • Z80 ERROR
« Reply #672 on: May 16, 2017, 04:48:14 am »
I have made a version for 0.185 "groovymame64_0185.017b_wiimote_linux_LCD_BLACKFRAME.tar.bz2" (51.4MB), available here: https://drive.google.com/drive/folders/0B1vsJyOrRLuceENhSE5xM2VQcmM
This build is different in the XINPUT aspect (NO_USE_XINPUT = 0)
Your issue seems to be more related to attract-mode handling the wiimote.
ves
« Reply #673 on: May 16, 2017, 01:11:51 pm »
Hi.
I uploaded a new iso with groovymame 185 no wiimote support, internal fix GroovyArcade for install, and others options.
Usb2joystick 20 pin support.
If there were lag, edit xorg file /etc/X11/xorg.conf
and delete "Option "ShadowPrimary" "on""
PhoneGuy
  • Crazy
« Reply #674 on: May 16, 2017, 07:58:19 pm »
Here is what I found with the "groovymame64_0185.017b_wiimote_linux_LCD_BLACKFRAME.tar.bz2" build
From a command line in a terminal from the LXDE desktop:  The limited mouse movement problem.
From Wahcade: limited mouse movement.
From Advmenu: limited mouse movement.
From Attract: No mouse control but mame does not freeze at launch.
Doozer
  • Z80 ERROR
« Reply #675 on: May 18, 2017, 03:05:28 pm »
Could you kindly elaborate more on how limited mouse movement materialises?
PhoneGuy
  • Crazy
« Reply #676 on: May 18, 2017, 06:39:08 pm »
Same symptoms as I posted earlier:
These executables do not have the mouse issue.  They cause mame to freeze when launched with attract-mode:
groovymame64_0184.017b_linux_LCD_FIX.tar.bz2
groovymame64_0185.017b_linux_LCD_FIX.tar.bz2
A 184 gm executable I complied and saved when I tried linuxmint-18.1-cinnamon-64bit.
Doozer
  • Z80 ERROR
« Reply #677 on: May 20, 2017, 03:58:45 am »
It sounds weird to me. I am using the (0184.017b_linux_LCD_FIX and 0185.017b_linux_LCD_FIX) and I do not have issue with AttractMode and Mame. I am using the Git version of attract and it runs smoothly.
I provide you my attract binary, please give it a try (https://drive.google.com/open?id=0B1vsJyOrRLucSTFqNUxaM1ZGNXc).
PhoneGuy
  • Crazy
« Reply #678 on: May 20, 2017, 03:39:13 pm »
This attract binary does the same thing.  In particular pacman comes up with the splash screen with the rom and resolution info and appears frozen.   I did find that if I ctrl-alt-f2 to another terminal window and kill attract then ctrl-alt-f1 back to the still running mame screen I can then right/left and the game finishes loading and is playable. If I change nothing but having attract-mode use the original 184 grooveymame binary included with groovyarcade then the game does not freeze but there is no mouse control.
osknatt81
  • Last login:February 21, 2018, 12:47:00 pm
« Reply #679 on: May 29, 2017, 01:47:31 am »
I have the 2013 groovy arcade live cd . How do I use an usb gamepad, I cant find a way to make it work.. thanks for help
