Author Topic: Joystick Swapping  (Read 1091 times)
nofxbam
  • Last login:July 09, 2016, 01:31:09 am
Joystick Swapping
« on: February 24, 2013, 03:50:17 pm »
Hi All,
I'm using the mag-stik plus and considering swapping to a different joystick with better 8 direction and longer throw. Does anyone know if those 4 screws that go from the top plate into the joystick are standard or in the same position as any other joysticks? I'm not talking about the mounting screw holes that go into the wood, just the inner 4 that go into the joystick. I'd like to keep the same plates if possible to avoid routing another control panel to fit another joystick's plating.
I am considering the UltraStik 360 now. Also open to any other joystick suggestions.  :afro:
« Last Edit: February 24, 2013, 03:52:31 pm by nofxbam »
