Author Topic: How to sand the borders of acrylic  (Read 1875 times)
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« on: November 05, 2003, 06:14:06 pm »
Hi,
Here I am again for another question for you "experts" on the subject ... ;D
I'm going to cover my Cp with an acrylic (believe you guys call it plexiglass) sheet 2mm thickness.
For the cutting / driling no problem ... I'l use metal apropriate.
The quesion is ... How or what should I use to make the borders smoth and kinda round without scratching it ?
Does metal sand papper 600 grain do the trick ?
Infrasonic
  • Last login:May 20, 2003, 01:28:03 pm
Re:How to sand the borders of acrylic
« Reply #1 on: November 05, 2003, 08:59:20 pm »
I would only sand using a sanding block, with the sandpaper fastened tightly onto it.  Also, it would probably be best to keep the protective plastic, and/or using masking tape to protect the area around the edges.  Using 600 may prove tedious, you could try starting with a coarser grade-like or 220, and move up to 600.  Remember acrylic is brittle and can break easily.  It has better scratch resistance that polycarbonate though, and is cheaper.  Sanding with water-wet wet/dry sandpaper is best.
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #2 on: November 05, 2003, 09:04:52 pm »
Heat works nicely. Try a propane torch on a piece of scrap, you just need to get it hot enough that the sharp edges melt and round themselves. Too hot and the acrylic will bubble or warp. With a little practice you'll find the right amount of heat to round the edges quickly and cleanly.
Zakk
  • Last login:February 06, 2026, 02:23:20 pm
« Reply #3 on: November 06, 2003, 12:22:45 am »
Only way I know of to get a real smooth finish is the buffing wheel.  Also takes a little bit of trial and error to get used to, but then it's a piece of cake:
http://www.mameworld.net/massive/How-to/Buff/buffing.htm
Infrasonic
« Reply #4 on: November 06, 2003, 12:55:09 am »
Be careful with that torch, acrylic is inflammable.
    • GroovyGameGear.com
« Reply #5 on: November 06, 2003, 01:42:48 am »
True, but don't let that stand in your way.
The pros flame-polish acrylic.  Just be careful, practice and take your time.
PedroSilva
  • Grettings !
« Reply #6 on: November 06, 2003, 05:13:31 am »
Hi,
Thank you all for the great ideas ... this is why I love this forum .. there's always someone who has already had and solved all my problems ...  ;D
Regarding the choice ... I think I'll try to use the suggestion from Zakk ... it's exacly that finish I'm looking ...
Last question:
Is there anything we can adapt to the power drill to do the job ? I don't want to by a buffing wheel just to do that.
Infrasonic
« Reply #7 on: November 06, 2003, 05:22:35 am »
you could use a file - I use files, it really doesn't matter what type of file you use double cut, single cut, or double-bastard.
My main purpose is to remove the sharp edges.  It takes me about a minute and it's done.
PedroSilva
  • Grettings !
« Reply #8 on: November 06, 2003, 05:29:46 am »
What's a file ?  ;D
Infrasonic
« Reply #9 on: November 06, 2003, 06:41:06 am »
here's a pic
PedroSilva
  • Grettings !
« Reply #10 on: November 06, 2003, 06:57:24 am »
I see ...
But with that you have to have a very good eye to maintain the same angle all along ...  ;D
I'll make the test anyway ...
Thanks,
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #11 on: November 06, 2003, 11:05:51 am »
Files are good for the bulk of the work.
The problem with any mechanical sander is heat buildup melts the plastic, which gets gooey.
Buffing plastic with a wheel is tedious too. It's really easy to press the material too hard into the wheel and melt it.
This is something you want to practice a lot before you try it out.
I don't think your drill press is going to spin any where near fast enough to work as a buffing wheel.
Bob
neuromancer
  • Can I Play?
« Reply #12 on: November 06, 2003, 11:06:02 am »
Bob
PedroSilva
  • Grettings !
« Reply #13 on: November 06, 2003, 11:13:39 am »
Bob
Damn ...
I'll have to spend more money ???
Gonna have to stop eating to balance ...  ;D
