Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1057951 times)
Gilrock
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2600 on: April 23, 2020, 08:51:40 am »
I was browsing that Minitendo on the website.  So its not clear to me those options for the marquee, bezel, and control panel plastics are you getting just the clear plastic or does it already have the artwork on the plastic?
  • Last login:Yesterday at 01:44:17 pm
« Reply #2601 on: April 23, 2020, 09:28:45 am »
Just the clear plastic. The art I invoice separately for.
Marquee goes behind the Plexi, bezel is laminated vinyl that you apply to the Plexi, and control panel overlay is laminated vinyl that applies directly to the control panel.
Gilrock
« Reply #2602 on: April 23, 2020, 09:52:39 am »
Thanks...I'm thinking about it cause my son wanted a project to work on.  But every time I hint at another bartop my wife freaks out....lol.
  • Last login:March 10, 2026, 05:35:00 am
« Reply #2603 on: April 23, 2020, 10:34:55 am »
Put a strap on it. Tell her it is a purse.
bsilverop
  • Last login:August 19, 2020, 08:31:36 am
« Reply #2604 on: July 29, 2020, 08:46:57 pm »
What’s the difference between this company and GameroomSolutions?
« Reply #2605 on: July 29, 2020, 08:50:15 pm »
bsilverop
« Reply #2606 on: July 29, 2020, 08:52:53 pm »
It helps me understand why I should have read that before ever ordering anything from GRS.. but what I’m not clear on is if these companies are owned by the same guy??
« Reply #2607 on: July 29, 2020, 08:56:50 pm »
No they most definitely are not.  Haruman's Customs is owned by me (Lee) based out of Arizona.  GRS is Ryan?  Not sure where he is based.
bsilverop
« Reply #2608 on: July 29, 2020, 08:57:59 pm »
Ugh, thanks. I meant to order from you but ordered from them instead and ended up with a $500 paper weight.
« Reply #2609 on: July 29, 2020, 09:01:27 pm »
Oh man.  Sorry to hear that :(
bsilverop
« Reply #2610 on: July 29, 2020, 09:04:14 pm »
Live and learn.. I had someone else waiting to see how mine came out before ordering, so I’ll send them your way instead!
Slippyblade
« Reply #2611 on: September 13, 2020, 05:34:10 pm »
You'll not go wrong. Haruman is a stand up guy with great product. I just wish he had a cabaret kit!
« Reply #2612 on: September 13, 2020, 05:41:03 pm »
I have cabaret kits.
Slippyblade
« Reply #2613 on: September 13, 2020, 05:47:53 pm »
I didn't see em on the website. I'll go look, again.
ZoNiE
  • Last login:December 25, 2020, 08:00:10 pm
« Reply #2614 on: December 25, 2020, 07:56:01 pm »
Hi, do you do full size models? I'm in AZ and can pickup if shipping is the issue with larger units.
Interested in an Asteroids or Full Berzerker...
« Reply #2615 on: December 27, 2020, 09:39:24 pm »
Yes I can do that.  :)  Being in AZ makes it much easier.
PatentGeek
  • Last login:April 05, 2021, 02:35:31 pm
  • RPi4 + RetroPie + 2-Player Widescreen Bartop
« Reply #2616 on: January 02, 2021, 08:47:47 pm »
Nearly done with my widescreen bartop build and just have a few questions:
- The kit came with plastic marquee retainers (top and bottom). What should I use to secure them to the cabinet?
- There are vertical batons for the back panel – presumably to make it readily removable. What should I use to fasten the panel to the batons?
- What should I use to secure the control panel to the horizontal (slightly tilted) batons?
« Reply #2617 on: January 03, 2021, 10:56:30 am »
Wood screws for the marquee retainers.
I usually attach the top of the back door with hinges and use a small piece of velcro to adhere the back door to the batons
Control panel on that kit I usually attach with industrial velcro on the batons and the top of the admin panel.  ("paint" the top of the admin panel with a thin layer of glue and wait to dry, then apply velcro.  Will stick better that way since it's raw MDF there).
PatentGeek
« Reply #2618 on: January 03, 2021, 12:44:50 pm »
Thanks, Lee! I think I might go with just velcro for the back panel, so it can be removed completely... any reason not to do that if the velcro is strong enough? (I have some velcro rated up to 15 pounds...)
« Reply #2619 on: January 03, 2021, 03:59:01 pm »
You could do that too.
cofh
  • Last login:May 13, 2021, 01:25:41 am
« Reply #2620 on: May 07, 2021, 11:50:51 pm »
Hi Haruman,
So sorry to bother you on here.
My 11 year old autistic son is absolutely determined that we build our own Minitendo Donkey Kong bartop, exactly as shown on your website Bartop Kits graphic.  I sent you a message via the Contact link on your website, but have not heard back in almost 3 weeks.
Can you give me an idea of the approximate cost to buy the finished cabinet it with all of the DK graphics?  I am also wondering if there is enough room to modify the control panel to have six buttons for some Street Fighter fun?  I live in Toronto, Canada so I'm also wondering what the shipping/duty costs would be (approximately).
Any help you can offer would be greatly appreciated.  I love your stuff and how easy it looks to assemble.
Thank you.
« Reply #2621 on: May 08, 2021, 04:15:45 pm »
Hi Haruman,
Thank you.
I will check my email for your message, I must have missed it.
bollwerk
  • Last login:November 20, 2023, 08:27:52 pm
« Reply #2622 on: August 09, 2021, 06:11:04 pm »
Haruman,
I don't suppose you have any sit down non-cocktail style cabinets, like either a Japanese style "candy cab", or something like what's in these pictures from Rec Room Masters (which they discontinued, sadly)?
I can't find any company that makes something like this at a reasonable price (under $1000 before shipping).
Ideally, I'd like a cabinet that does NOT house the monitor, but rather has a backmount, so I can install a rotating VESA mount, allowing me to rotate the TV and change between horizontal and vertical games.
I would be happy to pay you to design the files, if I can't get the CNC files from Rec Room Masters.
« Last Edit: August 09, 2021, 06:23:00 pm by bollwerk »
« Reply #2623 on: August 10, 2021, 12:16:25 pm »
I could do something like that.
Send me an email.  My username here @gmail.com
96p993
  • Last login:April 09, 2022, 01:26:37 pm
« Reply #2624 on: February 14, 2022, 05:37:38 pm »
Email sent this morning...Thanks
fvargasfrank
  • Last login:March 22, 2022, 10:23:34 am
« Reply #2625 on: March 21, 2022, 11:38:39 pm »
Are the plans for the bars-stick available? I went to the site but it's no longer active.
busbeepbeep
  • Last login:December 18, 2024, 09:10:03 pm
  • Just trying not to break anything
« Reply #2628 on: January 05, 2024, 12:03:12 am »
@haruman, I built a Widescreen EVO XR2 a few years back.  Have an issue with the control panel and the barrel hinges.   When playing fighting games with lesser experienced players who are rough with the joystick, the control panel starts to pull away from the bartop.  The magnets aren't strong enough and I guess the holes for the barrel hinges have loosened.
Any suggestions on ways to secure the control panel?  Even if I lose ability to quickly access the internals, that would be ok with me if find a way to way secure the CP and enjoy playing more.
« Reply #2629 on: January 08, 2024, 09:08:11 am »
You could always put a couple of bolts through the admin panel and the panel behind it...
Lingwendil
  • Last login:November 25, 2025, 02:11:48 pm
  • Here to check some cool builds out!
« Reply #2630 on: August 09, 2024, 06:53:33 am »
I see the website is no longer active, but I was interested in a kit. Are any still available?
« Reply #2631 on: August 09, 2024, 10:07:31 am »
Website has moved to haruman.com
Kits are available!
Lingwendil
« Reply #2632 on: August 09, 2024, 11:13:18 am »
Oh sweet!
Any baby kits for the usual 7" LCD screens that are common now? A smaller mintendo (microtendo???) Seems like a decent option for one since there's so few buttons to try to fit.
Or, are the design files still available so I could scale something down?
Thinking of using up some of the random tech I've been hoarding.
SNAAKE
  • Trade Count: (+29)
« Reply #2633 on: May 09, 2025, 12:12:02 pm »
you good? been trying to reach you about car's extended warranty the arcadepieces i was trying to order
