March 06, 2026, 09:14:35 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Main Forum
Question Regarding removing joystick
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Question Regarding removing joystick (Read 1481 times)
Yourname942
Trade Count:
0
Full Member
Offline
Last login:October 01, 2016, 08:10:20 pm
on:
February 18, 2013, 12:39:10 am »
There is a semicircular disc under the joystick which keeps it locked (so you can't pull it out)
I'm having a LOT of trouble trying to pry it out, idk what to do.
Does anyone know how to remove this?
Logged
Guest
Trade Count:
0
Re: Question Regarding removing joystick
Reply #1 on:
February 18, 2013, 12:43:01 am »
It's called an e-clip (or c-clip to some). Get a flathead screwdriver. Insert it into one of the gaps between the clip and joystick shaft. Rotate the screwdriver slowly and make sure the clip doesn't go flying across the room.
Logged
Global Moderator
Trade Count:
+1
Full Member
Offline
Last login:
Today
at 02:35:06 am
Designated spam hunter
Reply #2 on:
February 18, 2013, 12:47:20 am »
I assume that you're talking about the e-clip -- P/N 43-0019-00 in this diagram.
Use a small screwdriver to carefully pry it away from the shaft.
WARNING: They can shoot across the room and are easily lost.
Logged
KADE-compatible AVR vendors list
Yourname942
Trade Count:
0
Full Member
Offline
Reply #3 on:
February 18, 2013, 12:49:00 am »
after like 15 min I finally got 1 out, but that clip broke.. Do you know if they can be replaced? (can I buy that part at Lowes/Home Depot? (or a similar piece of metal)
Logged
Global Moderator
Trade Count:
+1
Full Member
Offline
Last login:
Today
at 02:35:06 am
Reply #4 on:
February 18, 2013, 01:11:48 am »
Which joystick do you have?
Happ Competitions use a 7mm clip. (43-0019-00)
JLFs use the ones you can get
here
or
here
EDIT: Another place to check is your local Ace Hardware.
Last Edit: February 18, 2013, 01:16:17 am by PL1
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
