Author Topic: Groovy Arcade gfx driver/xrandr mechanism  (Read 2929 times)
VanDusen
  • Last login:April 21, 2017, 05:10:36 pm
« on: February 08, 2013, 05:14:24 am »
Hello!
I tested groovy arcade with a Hantarex monitor and a simple breakout-cable (RGB/G/H/V) and its working.
Then i saved the xorg.conf and tried to use the modeline with lubuntu on the same hardware.
With a VGA2SCART-cable/TV-Set i get a picture. But non with the breakout-cable/Hantarex.
xrandr shows that the port where the breakout-cable is connected appears as disconnected and "xrandr --output DVI-1 --mode ..." doesn't work . With the VGA2SCART-cable/TV-Set it shows up as connected.
linux >xrandr --newmode "648x480x60.00-1525-1570" 13.129200 648 672 736 840 480 482 488 521 -HSync -VSync interlace
linux > xrandr --addmode DVI-1 "648x480x60.00-1525-1570"
linux >xrandr --output DVI-1 --mode "648x480x60.00-1525-1570"
linux > xrandr
240x240@58,795 48.7
DIN disconnected (normal left inverted right x axis y axis)
DVI-1 disconnected (normal left inverted right x axis y axis)
648x480x60.00-1525-1570 30.0
I don't belive that the old tube monitor sends EDID data. There must be some other kind of detection. How does Groovy Arcade do this?
Many thanks
VanDusen
« Last Edit: February 08, 2013, 05:24:46 am by VanDusen »
Calamity
  • Moderator
  • Last login:March 15, 2026, 04:39:26 pm
  • Quote me with care
Re: Groovy Arcade gfx driver/xrandr mechanism
« Reply #1 on: February 08, 2013, 06:36:37 am »
Arcade monitors are not detected by the video card so you need to force the specific output to stay on from boot. I believe this is achieved by adding -video VGA-1:640x480ec in grubs kernel line.
Steps to create a log:
VanDusen
« Reply #2 on: February 08, 2013, 08:43:38 am »
Many thanks!!! Works very well!
