Author Topic: MAKVISION 4827F1 stuck on disconnect when plugged in  (Read 1087 times)
mrcram
  • Last login:October 07, 2016, 05:47:03 am
  • OREGON STATE
« on: February 08, 2013, 01:22:13 am »
I have a Makvision 4827F1 vga monitor that appears great and is working.  I think it is a 29inch monitor. It should be high res and able to take a 640x480 60hz input from my computer to its vga input.  No matter what, it still reads the disconnect screen saver on the display.
I am running a Visiontek HD4350 though DVI to VGA output with dongle but have tried other settings also.  Any ideas?  The internet is blank when searching for the 4827F1 monitor.
mrcram
  • OREGON STATE
Re: MAKVISION 4827F1 stuck on disconnect when plugged in
« Reply #1 on: February 10, 2013, 02:07:23 pm »
So from researching, this monitor is only high res, no 15khz or anything.  It seems that there are people that have got it working with arcadevga3000 but had to use a vga/dvi adaptor on it.  There has to be some sort of setting I can use on my hd 4350!
