Author Topic: Question regarding Plexiglass  (Read 3357 times)
Yourname942
  • Last login:October 01, 2016, 08:10:20 pm
« on: February 05, 2013, 11:57:47 pm »
Does anyone know what the standard/common/ or recommended thickness plexiglass to use for the control panel/marquee/ bezel cover?
Thanks.
Edit: also what type of tool do you need to cut it to the shape/cut the holes for the buttons/joysticks?
  • Online Online
  • Last login:Today at 02:37:33 pm
Re: Question regarding Plexiglass
« Reply #1 on: February 06, 2013, 12:49:21 am »
Selfie shares his wisdom and experience here -- stickied in Woodworking Forum.
Dawgz Rule
« Reply #2 on: February 06, 2013, 05:59:15 am »
As far as thickness goes, it really varies.  I choose 1/8 inch on a 5/8 panel.  This allowed me to hide the edges with the T molding.
shponglefan
« Reply #3 on: February 06, 2013, 08:28:25 am »
Ditto.
Yourname942
« Reply #4 on: February 06, 2013, 09:08:52 am »
Sry, I should have clarified a bit more, I'm using 3/4" mdf. What thickness would you suggest? I'm not sure which to use that still lets the t molding to be flush.
shponglefan
« Reply #5 on: February 06, 2013, 11:44:32 am »
Do you already have the T-Molding?  Looking at T-Molding.com, they have 13/16 inch and 1 inch sizes.  That means you'd need either 1/16 inch Plexi (which is pretty thin), or 1/4 inch plexi to accomodate those sizes of T-Molding.
Alternatively, you could round the bottom of the 3/4 MDF so the height at the edges is 5/8 and then use 1/8 plexi and 3/4 T-Molding.  IMHO, 1/8 plexi is the easiest to work with and 3/4 inch T-Molding has the most options (colours, etc).
Or another option is to just redo the panel with 5/8 MDF and use 1/8 plexi per the above.
« Last Edit: February 06, 2013, 11:47:28 am by shponglefan »
Yourname942
« Reply #6 on: February 06, 2013, 12:29:45 pm »
nah I don't have the T molding yet.
What would be the better option to use 1/16" or 1/4" plexi for:
- control panel
- bezel cover
- marquee cover
I appreciate the help.
shponglefan
« Reply #7 on: February 06, 2013, 01:06:50 pm »
It depends on what is behind them.  1/16 inch will be extremely flexible*.  So you want a solid surface to brace it against.  For a CP, this is not an issue.  And thinner plexi will make it easier to cut and drill out the necessary holes.
But for something like a marquee, if you have a light-up marquee, you probably won't have a solid surface behind it.  So 1/4 inch would be better in that case.
* Just as a disclaimer, I've never worked with anything quite that thin.  Thinnest plexi I've used is about ~0.08 inch, which is pretty close to 1/16th.
Yourname942
« Reply #8 on: February 06, 2013, 01:19:58 pm »
Alright, ty. I think I'll just stick with 1/4 plexi for all the parts.
Dawgz Rule
« Reply #9 on: February 06, 2013, 03:41:51 pm »
For the bezel I would recommend glass over plexi.  Graylite 31 will really make the colors pop.  Also, it is less prone to scratching.
