Author Topic: Slowdown games using soft15  (Read 3343 times)
mitsurugi
  • Last login:November 07, 2025, 04:57:10 am
« on: February 03, 2013, 10:45:40 am »
Hello!!  :cheers:
I'm using windows 7 x64 with a hd4850 and soft15.
Windows run in 15hz, but when i try emulators 3d games have slowdown.
I have tested mame (games like tekken tag and psx 3d games), model 3, model 2 and all have several slowdown and choppy sound.
Demul only runs ok.
In monitor computer everything runs ok.
What could it be?
Thank you very much.
rCadeGaming
  • Just call me Rob!
Re: Slowdown games using soft15
« Reply #1 on: February 03, 2013, 09:02:42 pm »
If you're using Soft15kHz, are you using directdraw for native res in MAME?  If so, it's much more demanding than Direct3d, so the slowdown is normal.  You either need a faster processor, or do some compromising with Direct3D for problem games.  Sorry.
mitsurugi
« Reply #2 on: February 04, 2013, 04:13:37 am »
I have found problem. I had to disable v-sync and tripple buffer in all emulators and catalyst control center!
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« Reply #3 on: February 07, 2013, 06:30:33 am »
I have the exact same hardware than you do in every way so will try this. I'm running MAME .140 so what are the d3d compromises to expect if I go that route?
mitsurugi
« Reply #4 on: February 11, 2013, 10:06:43 am »
I really don't know what causes the slowdowns but 3d games run very very slowly.
I must disable v-sync and tripple buffer, and games run good in that case, but have several problems wich games like taito typex, because the launcher don't have graphics options and i can't disable it. Example: kof mi runs very very slowly!!
Maybe somebody can tell us where are the problem.
SailorSat
  • Last login:March 02, 2026, 11:07:22 pm
    • For Amusement Only e.V.
« Reply #5 on: February 16, 2013, 11:19:57 am »
What resolution you run the games at?
Interlaced resolutions on ATI can force you down to 30Hz.
mitsurugi
« Reply #6 on: February 17, 2013, 09:20:58 am »
In mame i put auto in resolution and in model 2 or model 3 800x600, but always you active v-sync or tripple buffer, slowdown, but the game shows correctly, only very slow.
SailorSat
« Reply #7 on: February 17, 2013, 10:03:13 am »
800x600 will be 50Hz, and with that ATI bug either 50FPS or 25FPS instead of 60.
Try 640x480 for model2
mitsurugi
« Reply #8 on: February 19, 2013, 11:28:39 am »
Thanks for your reply. This bug only affects ati cards? is there any way to repair it?
I have tried with the house of the dead 3 pc game, and same slowdown. I put resolution to 640x480 and same slowdown. Pc games always slowdown...
