Author Topic: Pushbutton adjustment? - gap between button and microswitch  (Read 1763 times)
Midcoastsurf
  • Last login:November 02, 2020, 11:19:14 am
  • I want to build my own bartop
« on: February 02, 2013, 08:35:56 pm »
I have some brand new pushbuttons, but there is about a 1/8" gap between the leg of the pushbutton and the microswitch button.  This means there is a "false" push before the button actually engages the microswitch.  Not sure if this makes sense, but my older pushbuttons don't have this "play" in the button.
Is there a way I can adjust these pushbuttons so the microswitch is touching the plastic on the pushbutton all the time?
The switch can be seen here:  http://tinyurl.com/b3kv5qb
Midcoastsurf
Re: Pushbutton adjustment? - gap between button and microswitch
« Reply #1 on: February 26, 2013, 11:25:09 am »
Just cheap pushbuttons?  Do the Happ buttons behave the same way when new?
« Reply #2 on: February 27, 2013, 12:24:11 pm »
there is always a little bit of space, though not as large as you describe.  a standard cherry switch and happ button has very little slop in it. (maybe 0.02 inch (about the thickness of 4 sheets of paper)) perhaps the switches you are using have a shorter than normal "peg".
if it really bothers you try cutting some plastic shims and super gluing it to the "foot" of the button. be sure to leave a little space, you don't want the button pressed down at all or you are going to run into a situation where you press down the button and the switch stays clicked and won't release.
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #3 on: February 28, 2013, 12:46:57 pm »
err... buy better buttons, or if youre doing it really cheap (cant fault anyone for that) , use a soldering iron and carefully melt/stretch the plastic into the position you want
Hit something hard enough it should work, if it dont the result can always be called art :)
