Author Topic: Mala and videos, log says video NOT found  (Read 3437 times)
Craz3d
  • Last login:March 05, 2013, 09:59:07 pm
« on: January 30, 2013, 08:59:17 pm »
Heres the excerpt from the log referring to when I select Mortal Kombat 2
2013/01/30  20:49:29.48   Debug **: DisplayMarquee:
2013/01/30  20:49:29.48   Debug **: LoadPicture: C:\Emulators\Files\Artwork\MAME\Marquee\mk2.png
2013/01/30  20:49:29.51   Debug **: DisplayCPanel:
2013/01/30  20:49:29.54   Debug **: LoadPicture: C:\Emulators\Files\Artwork\MAME\CP\mk2.png
2013/01/30  20:49:29.60   Debug **: DisplayDefinable1: Is not enabled in this Layout
2013/01/30  20:49:29.60   Debug **: DisplayDefinable2: Is not enabled in this Layout
2013/01/30  20:49:29.60   Debug **: DisplayDefinable3: Is not enabled in this Layout
2013/01/30  20:49:29.60   Debug **: DisplayDefinable4: Is not enabled in this Layout
2013/01/30  20:49:29.60   Debug **: DisplayDefinable5: Is not enabled in this Layout
2013/01/30  20:49:29.60   Debug **: DisplayVideo: Selected game # 47
2013/01/30  20:49:29.60   Debug **: DisplayVideo: Video2 NOT enabled/set in this layout
2013/01/30  20:49:29.60   Debug **: DisplayVideo: Video 1 Path = C:\Emulators\Files\Artwork\MAME\Video_MP4_HI_QUAL\mk2
2013/01/30  20:49:29.60   Debug **: LoadVideo:  In Function
2013/01/30  20:49:29.60   Info: LoadVideo:  C:\Emulators\Files\Artwork\MAME\Video_MP4_HI_QUAL\mk2 NOT found
2013/01/30  20:49:29.60   Debug **: LoadVideo: End Function
2013/01/30  20:49:29.60   Info: DisplayVideo: Master Did not Load : C:\Emulators\Files\Artwork\MAME\Video_MP4_HI_QUAL\mk2
2013/01/30  20:49:29.60   Info: LoadVideo:  C:\Emulators\Files\Artwork\MAME\Video_MP4_HI_QUAL\ NOT found
2013/01/30  20:49:29.60   Info: DisplayVideo: Clone did not Load : C:\Emulators\Files\Artwork\MAME\Video_MP4_HI_QUAL\mk2
I've got the newest version of Xvid installed and using video snaps form EmuMovies. The videos play in VLC without issue.
I've attached a couple other screenshots showing the layout (videos are enabled on it) and the menu settings I'm using. I feel like I'm missing something easy here.
honeyjew
  • Last login:January 06, 2024, 06:55:49 am
  • Building a 3/4 size Galaga
Re: Mala and videos, log says video NOT found
« Reply #1 on: January 31, 2013, 08:50:07 am »
Try renaming the MP4 file extension to AVI
« Reply #2 on: January 31, 2013, 10:05:14 am »
Might be your version of Mala
Mala v.174 did not support mp4 files
Mala v.1745 BETA  does
http://www.malafe.net/index.php?page=download
(website is back up. yay!)
Craz3d
« Reply #3 on: January 31, 2013, 02:04:41 pm »
Good idea, used
ren *.mp4 *.aviin command prompt and all videos work now!
Craz3d
« Reply #4 on: January 31, 2013, 02:05:05 pm »
FINALLY! Time for some layouts.
