Author Topic: Display Vertically Istead of Horizontally  (Read 1135 times)
CincinnatiKid1985
  • Last login:January 25, 2013, 03:29:25 pm
« on: January 25, 2013, 03:29:25 pm »
I am using advmame on Linux. If I have a 19'' wide screen, is it possible to display vertically. For example the left side of the monitor would be the bottom, and the right side would be the top in the game. Does this make sense?
Thanks,
David
Jack Burton
Re: Display Vertically Istead of Horizontally
« Reply #1 on: January 25, 2013, 07:52:22 pm »
Yes, just run the game with the option -ror to rotate to the right, and -rol to rotate to the left.
You can also permanently alter this in your advmame.rc file.  If you want only vertical games to rotate add this to the file:
vertical/display_ror yes
