Author Topic: First Build - MAME Retrocade  (Read 5157 times)
HollowPointAMG
  • Last login:January 30, 2013, 07:14:39 am
« on: January 17, 2013, 07:00:29 pm »
New here :)
Been working on this for a few days and so far I kinda like it.  I think I'll add some slight changes here and there.
What inspired me to build my own cab?  After seeing a video of Killer Instinct arcade and it's insanely huge differences from the SNES version, I wanted to play it old school style with a joystick and 6 buttons to get the real arcade feel.  Downloaded the emulator/rom and played it on my keyboard.  Not good enough!  So I ended up on x-arcade.com and picked up a dual joystick.  I saw they had cabinet kits which looked awesome but way too pricey.  Then it occurred to me...  Why not try and build my own?  Then the researching began and I found you guys  ;D
I'm going to go to the local hardware store next week and have them cut out the sides.  I don't have tools or the space to do it myself unfortunately :(
Here are some mock up pics I created:
Dimensions:
The outer shell of the cabinet will be made using 3/4 MDF.  The rear and front panels will most likely be 1/2" MDF.  Not sure what to use for the control panel, possibly bits of both.
PC I'm going to use:
AMD Athlon II X4
16GB RAM
OCZ SSD 60gb
160GB - to store all the games
Hyperspin 1.2 Interface
Creative Inspire 7.1 Speaker System
Going to use a 22" CRT NEC Multisync 1250+ I grabbed for free from work :)
As for the joystick/buttons,  I'm going to tear into the X-Arcade dual joystick and create my own control panel.
More pics to come soon!  Can't wait until next week when I start building.  There will be loads of questions for sure.
Phase 1: Design
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
Re: First Build - MAME Retrocade
« Reply #1 on: January 17, 2013, 07:34:57 pm »
Excellent!  If I may offer one small tidbit, as a fellow first-cab builder who is ~80% to completion -- might want to round off that inside corner on each side panel, just below the speaker panel.  This is assuming you are going to finish the edges with T-molding.  Mine is nearly as sharp an angle as what you have, and getting that T-molding to properly bend to that angle and fit in there real snug, and to do so without damaging or marring it.... well, it's a pain!  And this is with using the "fan" technique even.  If you just round it off a little, it will help a ton.  This really goes for all the angles but I found that one to be the biggest problem by far.
Anyways, look forward to your progress!
HollowPointAMG
« Reply #2 on: January 18, 2013, 11:04:25 am »
Thanks for the tip!  :)
Phase 1: Design
« Reply #3 on: January 18, 2013, 11:09:26 am »
Sonic and the other bloke aren't doing it for me.  You have a pretty nice SF thing going on, it'd be a shame to muddle it up with random characters done in a totally different style.
Round yer corners, that was good advice.
Re: Re: First Build - MAME Retrocade
« Reply #4 on: January 18, 2013, 02:24:00 pm »
Agreed on both.
mcseforsale
  • Last login:August 14, 2025, 10:40:54 am
  • Creepy Mario Dude
« Reply #5 on: January 18, 2013, 02:38:40 pm »
+1 on both.  Even if you round your corners using a quarter for the radius, it will help greatly in getting the T-molding in there.  That would still allow the "sharpness" of the angles you look like you're after.
AJ
  • Last login:Yesterday at 09:37:22 pm
« Reply #6 on: January 18, 2013, 03:47:45 pm »
Edit out Chun Li's underwear.
Perhaps make the cab wider so you can get a taller monitor.
HollowPointAMG
« Reply #7 on: January 18, 2013, 07:06:41 pm »
Thanks everyone.  I've rounded off the edges in my 3D model.
Took home the 22" CRT from work.  What a beast... Weighs in at 77lbs!
Phase 1: Design
monkeychunkuk
« Reply #8 on: January 18, 2013, 07:45:16 pm »
Hate to poo on you design but maybe a name change? Lots of cabs using that name including my bartop
Its a good name but....
dgame
  • I am no Jedi
« Reply #9 on: January 18, 2013, 10:32:07 pm »
Nice designs!
Retrocade is a cool sort of generic term for what we enjoy over here.
The moniker works for most MAME cabs.
The Original Retrocade?
EDIT: Retrocade Emulator picture
« Last Edit: January 19, 2013, 12:01:31 pm by dgame »
monkeychunkuk
« Reply #10 on: January 19, 2013, 03:09:05 am »
Nice designs!
Yup my bartop is a clone of someone elses build,
HollowPointAMG
« Reply #11 on: January 20, 2013, 08:55:01 am »
Yup lots of "Retrocades" out there.  I really like the name so I'm going to keep it :)  No Retrocade is in my area and my friends love the name.
Phase 1: Design
monkeychunkuk
« Reply #12 on: January 20, 2013, 10:18:33 am »
Yup agreed its a great name,cant wait to see the finished machine
mcseforsale
  • Creepy Mario Dude
« Reply #13 on: January 20, 2013, 01:09:53 pm »
Its' popular because it's timeless.  Walk into someone's house and see a "retrocade" machine and you know what it is.  See a converted Pac-Kong machine and you don't know.
It's like the profile of a Dynamo cab, Silhouette of Christian Hosoi doing a backside air, etc....timeless and easily identifyable from a distance.  :afro:
AJ
HollowPointAMG
« Reply #14 on: January 21, 2013, 07:34:31 am »
AJ
Haha well said!
I'm going to the local hardware store this week to have them cut out the outer frame of the cab.  Can't wait!  Will post pics once I get it all home.
Phase 1: Design
