Author Topic: CPWizard - Any way to reduce the "canvas" size?  (Read 2693 times)
aza9999
  • Last login:February 26, 2013, 06:54:22 am
« on: January 15, 2013, 04:58:30 pm »
When you create a new CPWizard layout the default size of the layout is larger than i need, im making a fairly minimalistic layout like this
to fit into my mala screen like so
The problem is after i generate them with the batch command i then have to go and run a script with photoshop to crop them so they will fit the panel. Is there any way to set the layout size so i can just export my panels at the right size (640x220)?
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
Re: CPWizard - Any way to reduce the "canvas" size?
« Reply #1 on: January 16, 2013, 07:45:35 am »
I posted a CP Wizard question last week and never got a response about something else.  But I went to CPWIzards page and the guy himself responded in like 15 minutes.  So I would go that route.
aza9999
« Reply #2 on: January 16, 2013, 07:59:12 am »
cheers i'll give that a go, was just hoping to see if anyone else had a solution already before bothering the programmer :)
eddiepants
  • Last login:November 20, 2018, 05:00:51 pm
« Reply #3 on: January 25, 2013, 11:58:35 am »
Change the background image for your layout.  If you change the background image to something smaller,  it will then change the canvas size.
aza9999
« Reply #4 on: January 25, 2013, 07:08:57 pm »
Perfect! I can't believe i didn't think of that one  :banghead:
Thanks!  :cheers:
