Author Topic: problems with blank display on arcade with Emu crt driver  (Read 2141 times)
petermet
  • Newbie
  • Last login:March 30, 2013, 04:46:09 am
« on: January 14, 2013, 03:05:58 pm »
I am rebuilding my mame cabinet and have changed from using Powerstrip to Emu's ATI driver's.
My problem is on Windows boot. I get the 31hz signal (split through Jpac) but when the Emu driver's kick in the screen goes blank. Plugging in my normal computer monitor at that stage does not help (also blank).
If i boot with the computer monitor connected i get the out of range signal once windows has booted, switch to the arcade screen and all working fine.
Any ideas what could be causing this? Also if i boot with groovyarcade the display is fine booting from arcade monitor.
Help please!!!
Calamity
  • Moderator
  • Last login:Yesterday at 03:39:39 am
  • Quote me with care
Re: problems with blank display on arcade with Emu crt driver
« Reply #1 on: January 14, 2013, 06:01:58 pm »
You probably need to use the other output (connector) of your video card.
Steps to create a log:
