January 30, 2026, 09:01:30 am
I was planning to map those to left and right click for mouse buttons. I wasn't sure if I should label them that way or not.
Unless you had another use for the coin buttons not in a game, why not make the coins mouse clicks? That would save you two buttons on the panel.
Quote from: DrChek on January 14, 2013, 04:21:09 pmUnless you had another use for the coin buttons not in a game, why not make the coins mouse clicks? That would save you two buttons on the panel.I'm going to remove the dedicated mouse buttons then. I have seen a lot of panels with space for mouse buttons, so I added them. I suppose I can always hookup a wireless mouse if needed. Thanks for the info.Frankly, the only reason I have 6 buttons for each player is that seems to be a common number in designs that I've researched. I don't typically play fighting games, so I'm not sure if I really need that many buttons.
Depending on the Trackball you use, it will function as a mouse in the OS so you get a functional mouse for "free".90% of arcade games that aren't fighters, especially the classics, can be played on three buttons or less. Not saying you should dump the other buttons, just telling you what you'll find in practice.
Quote from: DrChek on January 14, 2013, 04:42:47 pmDepending on the Trackball you use, it will function as a mouse in the OS so you get a functional mouse for "free".90% of arcade games that aren't fighters, especially the classics, can be played on three buttons or less. Not saying you should dump the other buttons, just telling you what you'll find in practice.I've got a trackball from GroovyGameGear, I should be able to hook the coin buttons up to the mouse buttons on the encoder and just map them to coin inside Mame, correct?
