Author Topic: Exidy shooter issue  (Read 1187 times)
Crow
  • Last login:January 22, 2013, 02:30:17 pm
Exidy shooter issue
« on: January 10, 2013, 10:03:56 am »
I need some help because I suspect I am doing something dumb here but I can't get any of the Exidy shooters to work on a newer version of MAME.  They work fine on an older version (.089) but when I try to run them on .145 I get the dreaded ROM or CHD not found error.  I have the ROMs in the ROM folder so MAME see's the game but they won't run.  Other games work fine though.
So what am I doing wrong?  Any ideas?
Re: Exidy shooter issue
« Reply #1 on: January 10, 2013, 10:42:47 am »
The roms have probably been renamed or updated in that time.
You need the version of the rom meant to work with MAME v.145
Crow
« Reply #2 on: January 10, 2013, 11:40:38 am »
I have tried to find later versions of the ROM's but there doesn't seem to be any that I can find.   Take Cheyenne,  I can only find version 1.0 of it anywhere.  I think others have gotten the Exidy games to work with later versions of MAME but I can't figure it out  :banghead:
« Reply #3 on: January 10, 2013, 01:23:57 pm »
I'm not talking about the revision of the arcade board.
MAME roms do not stay the same over time.  They are renamed, re-organized, redumped, etc.
There is a good chance that a rom from the time MAME v.89 will not work with MAME v.145
You need roms intended for MAME v.145
A lot of old ones will work (if no changes were ever made to them), but a fair number will not.
From the crossbow WIP history courtesy of http://www.progettoemma.net/
- 0.113u4: Exidy440 driver update [Zsolt Vasvari]: Added video timing from schematics. Added the 9 timing PROMs to the ROMsets.
So MAME is now looking for things that aren't present in your old roms.
A ROM newer than v.113u4 will probably work, but it's best to have ones that match your version of MAME.
Crow
« Reply #4 on: January 14, 2013, 10:45:59 am »
Yup I figured out what was missing and found the timing PROMS in another ROM,  Yukon I think it was.  Anyway Once I added them to the ROM's they all worked fine.
