Author Topic: Convert a 4 way joystick to an 8 way  (Read 4809 times)
trashcan
  • Last login:January 09, 2013, 06:13:17 pm
« on: January 09, 2013, 06:06:51 pm »
OK so I just bought a 4 way ultimate joystick (http://www.arcadeemulator.net/cgi-bin/shop/cp-app.cgi?usr=51F7784142&rnd=1537319&rrc=N&affl=&cip=108.222.163.164&act=&aff=&pg=prod&ref=Ultimate+Joystick&cat=Joysticks&catstr=HOME:Joysticks).  I meant to buy an 8 way, is there any way to convert the 4 way to an 8 way.   Like maybe changing the restrictor  plates?
Jumpman64
  • Last login:October 12, 2017, 04:58:42 pm
Re: Convert a 4 way joystick to an 8 way
« Reply #1 on: January 09, 2013, 11:24:04 pm »
Will defer to the more experienced folks here, but I would sure think so.  Got any pics of the underside?  The store seemed to only have the one shot from the top.
  • Last login:Yesterday at 10:19:39 pm
« Reply #2 on: January 09, 2013, 11:31:08 pm »
On the "Ultimate" stick, the Suzo-Happ site shows here that there is a different actuator for 8-way than 4-way.
To convert from 4-way to 8- way, remove actuator 95-1307-00 and flat washer 43-0057-00 -- replace them with actuator 95-0267-00. ($0.73 on the Happ site, you might want to PM Divemaster127 (you linked to his store in OP) to see if he has one for sale since he charges less than Happ for shipping.)
Protip: Find parts/details on Suzo-Happ site, but order them from Divemaster127.   :D
EDIT: Just noticed that you also need to replace 95-0268-00 8-way bracket with 95-1314-00 4-way bracket.  It is a non-stock item.
Adding the bracket swap changes the difficulty level from "clipping your fingernails" to "cutting out an ingrown nail" -- It's not major surgery, but it won't exactly be easy or painless, especially if you don't exactly know what you're doing.
If you ordered the stick from Divemaster127, you might want to ask him if he'll let you return/exchange it for a Happ Super ;D or Competition :), or an Ultimate 8-way if you have your heart set on that model. :dunno
« Last Edit: January 10, 2013, 01:11:20 am by PL1 »
RandyT
    • GroovyGameGear.com
« Reply #3 on: January 10, 2013, 12:15:23 am »
We don't do much with the Ultimates, so this is a guess, but if you have some of the levered microswitches on hand, you can try swapping them for the ones on the stick.  The smaller actuator just keeps you from hitting more than one switch at a time, and the switches with levers, perhaps with some minor tweaking, would likely get you the 8-way functionality.
