Author Topic: Golden Tee Sync /Display Help  (Read 3595 times)
nipsmg
  • Last login:March 07, 2026, 12:08:50 pm
  • ROONEY!! ERRGH!!
    • Arcadia
« on: January 07, 2013, 08:24:25 am »
Here's the situation:
I have a Golden Tee Complete boardset (green), along with a Jrok RGB -> TV board (ver 4.1, with component) and a Jrok SYNC Cleaner.  (Apparently the Golden Tee boards have some funky sync timings)
Symptoms:
TV in my arcade cabinet:  (Unable to get into any menus)
   - Svideo connection
   - vertically rolling picture (would be stable if not rolling).
   - Picture is off to the right.
Other 27" JVC TV:  (can get into menus, no controls for picture position)
    - svideo connection
    - Stable picture.
Ideally, I'd love to NOT change out the TV in the cabinet if i can help it in any way, but I will if need be.
My issue is the image being off to the right.  It's actually cut off on the right hand side.
I thought I read somewhere that putting a resistor (0.85uf?!) in line with the sync will "pull" the picture off to the left, however I've lost that link and I can't find it, and I don't want to do anything that could potentially damage the board / RGB encoder.
Any ideas how to re-adjust the position of the picture and/or fix the vertical rolling on the TV in the cabinet?
I appreciate any help you guys can give me.
TOK
  • The Game Always Wins
Re: Golden Tee Sync /Display Help
« Reply #1 on: January 07, 2013, 02:37:44 pm »
I had an issue using a converter from Golden Tee's default medium resolution to VGA. Total shot-in-the-dark, but have you tried switching the Golden Tee's dips over to standard res outputs and see if it will sync that way?
My problem was wacky colors and a very soft/unfocused image. When I put the board in standard res, the issue cleared up.
I'm not familiar with the JROK setup, I was using one off eBay that is commonly referred to as the Yaton adapter (he's the seller but not manufacturer).
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #2 on: January 07, 2013, 04:57:15 pm »
JROk's adapter requires STD resolution to begin with, so I've got nothing to try there.
  • Last login:March 08, 2026, 07:17:46 pm
« Reply #3 on: January 08, 2013, 10:49:46 am »
golden tee outputs something OTHER than standard resolutions.
resolution: 640x350
h-frequency: 25.7KHz
v-frequency: 60.6hz
pixel clock: 21.5khz
it's the 25.7khz that's the kicker.
the cga/ega frequencies the converter can handle are
14.5 - 16.5khz -which is cga
23.5 - 25.5khz -which is ega
30.5 - 32.5khz -which is vga
as you can see, the frequency falls just outside into the space between ega and vga
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #4 on: January 08, 2013, 12:00:39 pm »
which I'm assuming is why the picture is off horizontally a bit.  Still searching for a solution.
TOK
« Reply #5 on: January 08, 2013, 02:30:23 pm »
He's quoting the medium resolution outputs, but you said you're running the board in standard resolution. <?>
If that horizontal frequency is what you think is causing your issue, you don't have your GT board running in CGA.
nipsmg
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #6 on: January 09, 2013, 09:39:44 am »
The board is running in CGA.
There is a DIP-Switch on the board that switches between std and med res.
I missed that lilShawn was listing the med-res sync timings.  However, I'm wondering if there's a similar issue with Std. resolution output as well, maybe it outputs 16.7 or something?
