Author Topic: xxxx in 1 wiring  (Read 1381 times)
redfivexw
  • Last login:March 11, 2025, 03:54:00 am
xxxx in 1 wiring
« on: December 26, 2012, 05:21:06 pm »
I got a 2019 in 1 board the other day, i wired it up with the atx power supply to an LCD monitor.  I dont get any response from the controls, however.  I can see the picture and it looks like it should work, but no controls work.  Do i need to wire up the regular switching power supply as well?  I have never used these boards so i am unfamiliar with the requirements, anybody have one of these?
grantspain
Re: xxxx in 1 wiring
« Reply #1 on: December 26, 2012, 06:54:43 pm »
yeah i have a few,its probably down to your switch common
are you using a standard jamma loom?
redfivexw
« Reply #2 on: December 26, 2012, 07:12:47 pm »
yes,
it is a fully populated jamma harness.  right now i have the board running off the atx supply, it powers up and comes on screen.  I have the jamma harness connected, but i did not hook up the power leads from that harness, i was not sure if it needed them.  I have wired many cabinets, so i know how to wire, but not sure if it needs the power leads hooked up.
