Author Topic: NEED ARCADE TECH IN FOR JOB IN NYC AREA!  (Read 2184 times)
DUDLEY33
  • Last login:December 21, 2012, 04:41:39 pm
« on: December 21, 2012, 04:18:01 pm »
HeLLO guys! I am looking to hire an arcade tech in the new york city area (Bronx, Ny)to come to my home to help me fix a midway 4 player nba jam arcade game I had taken apart. I had to take apart the machine in order to fit it through my door but now its all reassembled cabinet and all, yet the monitor turns on and shows nothing but swiggly lines. Please respond back if your willing to take the job, I'm sure its just a wiring issue. Thank you! my email address is: yahomeboyromeo@aol.com
Jigenjuke
Re: NEED ARCADE TECH IN FOR JOB IN NYC AREA!
« Reply #1 on: December 21, 2012, 05:51:29 pm »
Dudly33,
You probably don't need a tech to come and fix it.  Check all the connections again, make sure they are connected correctly.  Make sure all the ICs (Integrated Circuits or Micro Chips) are seated nicely.  Also check your wiring harness where it connects to the boards.
Good Luck
Jigenjuke
jmike
« Reply #2 on: December 21, 2012, 09:00:08 pm »
If you take pics maybe someone here can figure it out for you.
Just focus your pics on the connections.
MacGyver
  • Last login:December 18, 2023, 12:49:00 am
    • Project Build
« Reply #3 on: December 30, 2012, 02:19:27 pm »
He must of found someone else to get a kidney from.  >:D
