Author Topic: Having trouble emulating Ikaruga in Makaron with Vertical screen  (Read 3081 times)
glorble
  • Last login:December 21, 2012, 04:25:31 pm
« on: December 21, 2012, 06:21:33 am »
Edited:
I found this thread on this site: http://forum.arcadecontrols.com/index.php?topic=106477.0
Here is the code for convenience (with the NAOMI path edited):
Send, {CTRLDOWN}{ALTDOWN}{Left}{ALTUP}{CTRLUP}
Gui -Caption +ToolWindow
Gui, Color, 0
Gui, Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%, HSHIDE
Gui, 2: +AlwaysOnTop -Caption +ToolWindow
Gui, 2: Color, 0
Gui, 2: Show, x0 y0 h%A_ScreenHeight% w%A_ScreenWidth%, HSHIDE
MouseMove, 1439, 100
Run, C:\NAOMI\NAOMI.exe ikaruga.dat
sleep, 1200
WinSet, Style, ^0xC00000, NAOMI - PVR
WinActivate, NAOMI - PVR
Gui, 2:Destroy
MButton::
Process, Close, NAOMI.exe
Gui, Destroy
Send, {CTRLDOWN}{ALTDOWN}{Up}{ALTUP}{CTRLUP}
ExitAPP
return
Running the code gives me this error:
How do I get rid of this error?
If there are any further tweaks required for the autohotkey script, could you help me with that? I've already downloaded autohotkey and irotate. I've installed the Unicode version of autohotkey.
I would just play it horizontally, but it seems to make the game 12 times harder. And it's already pretty much way too hard for me as it is. =\
« Last Edit: December 21, 2012, 07:51:25 am by glorble »
Re: Having trouble emulating Ikaruga in Makaron with Vertical screen
« Reply #1 on: December 21, 2012, 08:55:22 am »
To answer your original question, Makaron 12/5 is here:
http://dknute.livejournal.com/34884.html
Does Makaron work fine when not using the script?
How about if you rotate the screen with irotate yourself, then launch the game?
Make sure you have both of these DirectX and C++ runtimes installed
Even if you have a brand new version of directX, it won't have these older runtimes installed.
(I know it's nulldc.  makaron uses the same ones)
http://code.google.com/p/nulldc/
EDIT: Kinda looks like it's not finding the BIOS.  I know when launching Makaron via command line, the roms have to be in the same folder as NAOMI.exe
         I don't remember about the bios.  Try putting a copy of it there.
« Last Edit: December 21, 2012, 09:08:05 am by BadMouth »
glorble
« Reply #2 on: December 21, 2012, 03:44:19 pm »
Running it by itself with irotate works.
Thank you. ^_^
« Last Edit: December 21, 2012, 03:52:29 pm by glorble »
« Reply #3 on: December 21, 2012, 04:39:59 pm »
Thank you. ^_^
Try it with the rom and bios in the same folder as NAOMI.exe
You can add another sleep to the autohotkey script before the line that launches Makaron.
That will make sure the screen has had enough time to rotate before launching it.
(I don't think this is the issue, but it's something else to try)
sleep, 500
You an also comment out all the Gui lines by putting a ";" in front of them.
That way the screen won't be blacked out and you can see what's going on until you get it working.
