Author Topic: Mounting LCD  (Read 1301 times)
Evilpenguinj
  • Last login:February 11, 2021, 09:28:10 am
Mounting LCD
« on: December 20, 2012, 11:53:36 am »
Hi Guys
I am putting an LCD in my cabinet and I wondered at what angle should it be at.  Is there a standard that I should be adhering too?
Jason
Unstupid
Re: Mounting LCD
« Reply #1 on: December 20, 2012, 01:00:31 pm »
You can mount it at any angle... but it will work best if that angle you mount it will allow the screen to be perpindicular to your face...
MonMotha
Re: Mounting LCD
« Reply #2 on: December 20, 2012, 06:16:04 pm »
If you intend to mount it at a fairly steep angle (parallel to the plane of the ground like in a cabaret style), you may find that the viewing angles from "below" are pretty terrible on most monitors.  It's often much better from "above", so you can turn the monitor around and use the appropriate driver option to fix the image.  Some commercial arcade games do this.
Note that IPS panels won't do this nearly as badly, but they cost a lot more.
