Author Topic: Windows task bar showing up in mala!  (Read 5631 times)
Furry131
  • Last login:January 10, 2020, 10:55:54 am
« on: December 16, 2012, 06:17:53 pm »
Hey everyone,  so I am having issues with the windows task bar showing up after I exit a game in mala. I'm not really sure why this is doing this but it's pretty annoying. They only way to get it back is to left click on your mouse.
I am running mala 1.7.4.0   MameUI 32 1.22.  I am on windows xp
I also have focuslogger plugin set up.  Any ideas?
matt4949
Re: Windows task bar showing up in mala!
« Reply #1 on: December 16, 2012, 07:11:35 pm »
go to option in mala go to GUI go to display go to Misc and turn off Show windows taskbar
Furry131
« Reply #2 on: December 16, 2012, 07:44:13 pm »
Well it figures it would be something so simple!!!  Thanks for the help. I feel like a dumbass now! Lol:-D
matt4949
« Reply #3 on: December 16, 2012, 07:56:16 pm »
No problem and don't ever forget ain't none of this easy and the sole reason for this forum is to help each other.
sockgoblin
  • Last login:November 13, 2017, 12:01:17 pm
  • beer will make it better
« Reply #4 on: December 17, 2012, 04:34:29 pm »
which skin are you using?
Furry131
« Reply #5 on: December 17, 2012, 06:31:12 pm »
It's a slightly modified version of this-------> http://malafe.net/index.php?page=layouts&subpage=aliendashboard
Skoremore
  • Newbie
  • Last login:September 02, 2013, 12:53:35 am
« Reply #6 on: March 29, 2013, 11:54:24 pm »
I'm having the same problem, but with Windows Vista.  I unchecked the box, "Show Windows Taskbar" and now the task bar is gone, but the little Start menu circle (windows vista) is still showing up in the lower left corner.  Even though the task bar is gone, the same problem is taking place.  I have to left click in order for everything to keep working. Very annoying. Any ideas?
deviantla
  • Last login:May 08, 2013, 03:09:39 pm
« Reply #7 on: May 08, 2013, 02:41:45 pm »
I created a batch file that launches Mala at startup. Prior to launching the mala.exe, it stops explorer.exe. That should elimiate the problem altogether, along with freeing up some resources. When you quit Mala (assuming you are not shutting down), simply tell Mala to launch explorer.exe in the settings.
loadman
    • MaLa
« Reply #8 on: June 22, 2013, 11:13:56 pm »
That is a good idea.
Can you post the batch file?
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
« Reply #9 on: June 23, 2013, 03:03:16 pm »
Doesn't windows automatically restart Explorer.exe whenever it is closed?
