Author Topic: Questions about building Virtual Pinball Cabinet  (Read 4175 times)
Savannan
  • Last login:December 22, 2012, 10:53:06 pm
« on: December 13, 2012, 01:46:38 pm »
Hello All,
Every other winter I like to take on a project to cure my Cabin Fever blues(besides Snowbaording)... 2 years ago I purchased a MAMEROOM UAII cabinet (which I play at least 3x a week...LOVE IT), Last year or so ago I made a Multi-MORTAL KOMBAT Arcade Cabinet
http://forum.arcadecontrols.com/index.php/topic,121304.msg1286764.html#msg1286764
Didn't want to sell it but I needed money for my pooches chemotherapy treatments.
But this winter I would like to start building a Virtual Pinball Machine.   I was opting to buy a kit, but the price is pretty expensive.  I'm good at wood working and thought I would build a cabinet from scratch instead of buying a pre-fab kit. When I build something, Im VERY VERY VERY matriculate(not anal) in presentation inside and out.
Just have a few questions that hopefully someone could answer for me.
1)  I was thinking of making a cabinet out of 3/4" oak 4x8 plywood (I believe its laminate..***don't quote me***).  I would try to stay away from chrome metal parts but use black instead...I wouldn't use metal legs but some fancy wooden ones...Do you guys think a pinball machine made like this would look good or decent?  or should I just paint everything black like all the others?
2) Any plans out on the net for a wide body pinball cab?
3) If you look at this youtube video :
He mentions that he uses a 19" LCD for the score area.  It looks hes only using the upper half of the monitor.. Is this correct?
4) The lauch ball plunger :  In the video he uses a push button to launch the ball.  Is there a plunger that looks like the real thing but actually has a potentiometer so the further you hold back, the faster the ball launches like in a real machine.
Any help would be very appreciative
Thank You
Sav
spoot
  • Destroyer of electronics
Re: Questions about building Virtual Pinball Cabinet
« Reply #1 on: December 13, 2012, 02:23:13 pm »
Nanotech sells a digital plunger and motion sensors for doing virtual pinball.
  • Last login:Today at 10:48:50 am
« Reply #2 on: December 13, 2012, 08:28:42 pm »
In that case, be sure to matriculate at the VP Forums to assist with your meticulous preparations.   ;D
I like the idea of a wood pattern cab with black trim.
http://forum.arcadecontrols.com/index.php/topic,84133.msg1090265.html#msg1090265
Looks like you are correct.
Ah, the age old question of plunger vs ball launch button.
Nanotech plunger - Available here or here.
Good news: Designed to work perfectly with all FP tables and many VP tables.
Bad news: Some people over at VPForums have had problems with getting the nudge accelerometers properly calibrated for their cab.
Some tables like T2 used a trigger to time the skill shot, not sure how well that would work with the plunger.
Launch Button -
Good news: Works with all tables.
Bad news: Pull strength depends on timing.
Another option is to have both like the link in my sig.
« Last Edit: December 13, 2012, 08:31:43 pm by PL1 »
Savannan
« Reply #3 on: December 14, 2012, 01:51:49 pm »
Thanks for your help guys...I know where to start....
but
Im guessing that link above is for a widebody plans..but the link doesnt work.
Thanks again guys!!!
Sav
« Reply #4 on: December 14, 2012, 02:07:54 pm »
I'd stick with metal legs, personally. Anything else would probably just look odd.
« Reply #5 on: December 15, 2012, 05:09:29 am »
PDF for the widebody is at http://forum.arcadecontrols.com/index.php?action=dlattach;topic=84133.0;attach=186655.
