Author Topic: Custom built arcade control panel FS (USA)  (Read 1427 times)
Dragonman73
  • Last login:April 08, 2018, 07:48:01 pm
« on: December 13, 2012, 10:51:50 am »
$250 + shipping to lower 48 states
What I have is a custom built control panel, covered in black Formica. There are a few light scratches here and there, nothing major. Maybe a 8 on a 1-10
Dimensions are roughly 34" long  x 14" deep x 7" high at the rear.  I had this based on a Run N Gun 4-player arcade cabinet which is identical to 4-player X-Men, Simpsons, TMNT...and similar games. If you have a cabinet with a flat base this should fit ok, just do your research first.
Here's what it has:
All buttons are LED buttons
Two (2) Eight way joysticks for P1 and P2  + 6 buttons per player
One (1) Four way joystick for P1 + two buttons
Illuminated 2-1/4" Trackball mouse that works off a Ps/2 port and has a usb adapter on it
Buttons for trackball mouse
P1, P2, Enter, Exit, and pause buttons (all labeled)
The coin 1 and coin 2 wiring is there, I will throw in basic buttons for that
I-Pac 2 with 32 inputs (usb version), wired to all of the controls...with a few inputs left for expansion
Led wiz, wired to all of the buttons that light up
Control panel is made of 3/4" mdf,  hinged, and has latches on the rear for easy access. I built this myself
Asking price is worth it in the parts alone, compare to the same type panels selling for double the price
« Last Edit: December 21, 2012, 09:19:07 am by Dragonman73 »
Dragonman73
Re: Custom built arcade control panel FS (USA)
« Reply #1 on: December 21, 2012, 09:19:25 am »
Bump
