Author Topic: Which version of Mame?  (Read 1702 times)
Sshado
  • Last login:October 04, 2024, 06:10:57 pm
  • Sshado's Club
    • Sshado's Club
« on: October 31, 2003, 11:42:50 am »
I am building a mini Arcade for a friend which will house a PII 333mhz CPU.  Which version of MAME should I use for this one?
Thanks,
Sshado
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
Re:Which version of Mame?
« Reply #1 on: October 31, 2003, 12:55:05 pm »
I like .61
but the latest is good afaik. I haven't heard anything bad yet about the new release.
Wade
  • Last login:August 18, 2025, 08:14:20 am
  • 80's Child
    • Wade's Gameroom
« Reply #2 on: October 31, 2003, 01:11:20 pm »
With a machine that speed, I would go with an older version of mame that performs better, like .036 or 0.37.
Wade
Lilwolf
« Reply #3 on: October 31, 2003, 01:30:11 pm »
.36 I believe is the last version that has 8bit color... This really speeds up a lot of games.
This was a big change in speed.
I would look at that.
Sshado
  • Sshado's Club
    • Sshado's Club
« Reply #4 on: October 31, 2003, 01:45:14 pm »
How do you find older versions of Mame32?  Sorry, don't mean to look dumb, I have searched the Mame32 site http://www.classicgaming.com/mame32/
Sshado
mrhowell
  • Last login:August 01, 2025, 09:42:31 pm
« Reply #5 on: October 31, 2003, 01:48:24 pm »
What is that pappy?
Lilwolf
« Reply #6 on: October 31, 2003, 03:20:09 pm »
btw, dont run mame32 if you are worried about speed.
Thats your first speed up there...
Go command line if possible.  of course with those old versions, the command line is DOS... but thats ok... you shouldn't be using winNT or XP on that system anyway.  98 runs the dos version just fine.  You might have a sound card issue... but you will probably be fine.
Also, look at non-mame emulators wherever possible.  Almost every other one is MUCH faster then mame.
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
« Reply #7 on: October 31, 2003, 05:43:27 pm »
I'm working on a project with a 400 mhz machine running .59.  Works great, I can run over 90% of the roms.
