Author Topic: 2-Player Street Fighter Themed Bartop  (Read 18367 times)
CoryBee
  • Bopity Boopy
« on: December 03, 2012, 05:42:46 pm »
Number 3 - "2 Player Bartop"
Got a ton of the work done last night, side panels were already cut and shown in this thread "Trio of Bartops"
Side panels trimmed to accept the future control panel box
Supports added
Chose to use particle board for the base because my MDF board is too thick, would add to much height to the thing
Cp base glued and clamped in place, all screws used on this are just to hold pieces together and will be removed and filled up after it dries
Cp top cut and rounded
Sanding any blemishes or miss cuts
Smooooooth
Laptop mount made out of 0.75" x 0.75"
« Last Edit: December 03, 2012, 05:44:38 pm by CoryDee »
fighterfanatic
  • Last login:November 30, 2023, 12:53:13 am
  • Down Right Fierce
Re: 2-Player Street Fighter Themed Bartop
« Reply #1 on: December 03, 2012, 05:48:25 pm »
 :applaud: Nice. Tuned in! Eagerly awaiting updates.
CoryBee
  • Bopity Boopy
« Reply #2 on: December 03, 2012, 11:12:02 pm »
Speaker panel cut and added
Paint + Speaker holes drilled and special gap routed behind it
CoryBee
  • Bopity Boopy
« Reply #3 on: December 05, 2012, 09:51:25 am »
Had to remove the control panel cause I forgot to route for t-molding first, not a big issue. Also easier to add the final layer of paint with it off.
Routed
I broke one of the contacts on the speaker that came on the PC amplifier (cheap thing), so I replaced both of them with some TV speakers I had from a broken screen set. Hooked up to the amp and all is well again, actually sounds way better.
« Reply #4 on: December 05, 2012, 10:14:58 am »
I can't keep up with all your builds.  :dizzy:
CoryBee
  • Bopity Boopy
« Reply #5 on: December 05, 2012, 10:18:59 am »
Me too half the time, with this and building ten computers at the same time, I have got my hands full for sure.  ;D
jmike
« Reply #6 on: December 05, 2012, 10:20:51 am »
Well done CoryDee.
      you are staying busy these day.  :applaud:
This reminds me of a SF bartop I did a couple of years back. Mounted the CP the same way. (but it made it really heavy).
Gave it to my brother (sorry I don't have any finished pics)
CoryBee
  • Bopity Boopy
« Reply #7 on: December 05, 2012, 10:23:06 am »
Well done CoryDee.
Unfortunate you don't have any completed pictures. I love the bobble head like characters
fighterfanatic
  • Down Right Fierce
« Reply #8 on: December 05, 2012, 10:25:05 am »
Always wondered about bartops; WRT Street Fighter and more "complex" games, how's the two player playability considering the close spacing?
CoryBee
  • Bopity Boopy
« Reply #9 on: December 05, 2012, 10:40:15 am »
This one is pretty much identical to the lightning two player bartop I made. That one was actually just perfect enough to not be too big and not too small to be played two-player without bumping each other. Granted you are not standing in front of it like a full size so it isn't a problem to be at a slight angle. I really don't like the idea of the width of the control panel being the width of the entire cab. The game I find myself playing with others the most is Marvel vs Capcom 2 and it plays beautifully on the thing.
fighterfanatic
  • Down Right Fierce
« Reply #10 on: December 05, 2012, 02:01:04 pm »
Awesome.  And that's what got me thinking, I noticed your larger control panel. It all makes sense, good to know.
GnobarEl
  • Last login:February 21, 2019, 04:58:34 pm
« Reply #11 on: December 05, 2012, 06:18:48 pm »
This is getting great! can't wait to see it fully working!
CoryBee
  • Bopity Boopy
« Reply #12 on: December 06, 2012, 07:32:13 am »
Cut the acrylic for the CP, then used the flush trim bit on the bastard to keep it clean
Tiny screws to hold it in place - ( angled shot )
Got my Avery stickers in and clear coat in hand - Let's see how it works out
Test print to get everything perfect - ( make sure to set the printer settings to label )
The clear coat should soak into the sticker and let the aluminum shine through
CoryBee
  • Bopity Boopy
« Reply #13 on: December 07, 2012, 04:21:28 am »
Back panel work - organizing the spots, drilling starter holes, routing out the other side so they can screw in properly
Primed and painted 1st coat
« Reply #14 on: December 07, 2012, 01:32:01 pm »
Well done CoryDee.
I made one too, 5 years ago and I also gave it to my brother. I think people request a 2 player bartop because they want the best of both worlds. They want to play 2 player street fighter AND they want to save space. Personally, they should give up on trying to save space because once the machine is this big, it needs a special stand or something to hold it up. Should just go with a full size.
Here's mine:
CoryBee
  • Bopity Boopy
« Reply #15 on: December 07, 2012, 05:47:41 pm »
This two-player is actually quite toight, fits almost everywhere my single player ones can fit. This design is quite space saving.
CoryBee
  • Bopity Boopy
« Reply #16 on: December 08, 2012, 04:30:09 am »
Back panel electronics installation - one of my favorite parts
Ended up putting one of the terminals on the bottom because I didn't like how the power wires were being stretched a little bit
I apologize for the ---smurfy--- pictures taken in this room, the lighting is horrible for my camera
Aluminum marquee retainers (these ones fit!) - they are currently drying from paint
Side by side shots with the single player build here "Link"
Don't mind the resolution issue or the "blue screen of death" - these laptops haven't had windows reinstalled on them yet
One on the left I painted the side panels, the one on the right is vinyl
CoryBee
  • Bopity Boopy
« Reply #17 on: December 08, 2012, 07:56:48 pm »
Art
Marquee
Control Panel
Boot Logo
CoryBee
  • Bopity Boopy
« Reply #18 on: December 08, 2012, 10:04:53 pm »
Art Printed
rCadeGaming
  • Just call me Rob!
« Reply #19 on: December 08, 2012, 10:15:53 pm »
I think the Street Fighter marquee needs more.  It's just those three things floating in empty space.
Mainly it's bad in comparison, because that control panel art is so detailed.  That looks reeeeeaally cool.  Where did that come from?  Link?
CoryBee
  • Bopity Boopy
« Reply #20 on: December 08, 2012, 11:01:15 pm »
I left it blank like that because the cab is a solid black and figured it would look nice
Link to CP orig. image
Image I used is flipped, gave this one because it is a much higher quality\size
rCadeGaming
  • Just call me Rob!
« Reply #21 on: December 08, 2012, 11:16:32 pm »
That's cool.  Is that Alpha artwork?  I noticed all the original characters are one side with the Alpha ones on the other.  I'm trying to remember where I've seen "Street Fighter" written that font style...
CoryBee
  • Bopity Boopy
« Reply #22 on: December 08, 2012, 11:19:44 pm »
Not sure brother man, just liked it for the control panel
CoryBee
  • Bopity Boopy
« Reply #23 on: December 09, 2012, 05:15:31 am »
Had to kick up some more dust to get the art applied
CP art on and buttons half in
Marquee looks really nice - minus the dust, need to clean that up as usual when it is all completed and the acrylic loses some static
More of the CP and the finished artsy stuffs
floriske.nl
« Reply #24 on: December 09, 2012, 06:37:51 am »
Well done CoryDee.
Here's mine:
I'd have to disagree on that.
In my case for instance the bartop (which sizewise is sort of between a full size without the bottom part and a bartop) will most of the time have it's place in my "mancave" on our attic but on occasion I want to be able to use it in the living room as well (parties etc.).
In case of a full size it would be hell to get it downstairs and we'd have to move furniture around to give it a good spot. But with my bartop design it's a lot easier to move and we can simply put it on our table or kitchen bar.
Ontopic: going like a fast train there Cory ;) looking good so far.
« Last Edit: December 09, 2012, 10:21:28 am by floriske.nl »
CoryBee
  • Bopity Boopy
« Reply #25 on: December 09, 2012, 06:59:34 am »
Thanks floriske!
Am deffinately on track to have it done before christmas, more like a few days of software...or one. We will see, still waiting on the trackball mouse from the ebays for the minecraft build. And the.....uh Jim Morrison themed thingy I am almost done with as well. That one and this street fighter one are neck in neck to be finished nearly the same time.
« Reply #26 on: December 09, 2012, 08:06:30 am »
In my case
In that case - build 2.  :)
floriske.nl
« Reply #27 on: December 09, 2012, 10:23:42 am »
In my case
Smart#s  ;)
That's not an option, we don't want a bartop permanently in our living room and don't have the space for a bartop and a full size on the attic.
« Reply #28 on: December 09, 2012, 11:17:13 am »
the artwork is by Udon , I used it on my Neo2MAME:
I have to agree that the marquee is lacking, it just looks too "meh" even just a giant SF logo on white would look better.
CoryBee
  • Bopity Boopy
« Reply #29 on: December 09, 2012, 11:48:43 pm »
Nice build, that is one hell of a marquee area though  :applaud:
I am working on some art for the marquee to replace it, any suggestions would be nice
Termin8tor
  • Last login:August 04, 2020, 01:54:23 am
« Reply #30 on: December 13, 2012, 11:06:41 am »
I went with a ryu's stage for my marquee background on my SF cab. There are Hi-Res images available from the Street Fighter 2 HD edition. Just a thought.
« Last Edit: December 13, 2012, 11:24:01 am by Termin8tor »
Louis Tully
« Reply #31 on: December 13, 2012, 12:32:02 pm »
« Last Edit: February 12, 2015, 03:08:46 pm by Louis Tully »
CoryBee
  • Bopity Boopy
« Reply #32 on: December 18, 2012, 01:29:41 pm »
Spray the bezel!
Re-Spray the back panel because I didn't like the way it looked
Showed the customer some pictures to choose the marquee and he told me to keep the one I already made. Hey Mikey....he likes it!
And cause I am bored, I give you;
Yoshi eating Blinky
CoryBee
  • Bopity Boopy
« Reply #33 on: December 18, 2012, 08:35:26 pm »
Back panel looking extra shinny now!  :applaud: Just how I like it, getting better at this whole paint thing (baby steps anyways)
Anyways, 2 of 3 bartops complete   :woot
Couple pictures and a quick video of the boot screen and what have you
Video
Edit: Long gameplay test video
« Last Edit: December 18, 2012, 09:12:17 pm by CoryBee »
rablack97
« Reply #34 on: December 18, 2012, 09:04:11 pm »
Dude.......
You've come a long way man......... :applaud: :applaud: :applaud: :applaud: :applaud:
Keep up the progression!!!!!!
CoryBee
  • Bopity Boopy
« Reply #35 on: December 18, 2012, 09:13:40 pm »
Dude.......
Thanks a ton man  :laugh:
I see many more builds in my future! I got a fever, and the only prescription is more cowbell (projects)
rCadeGaming
  • Just call me Rob!
« Reply #36 on: December 18, 2012, 09:17:40 pm »
Nice boot screen.  The cab looks good overall, but the quality of everything else does still kind of make the marquee look weak by comparison.
Looks like you've got some orange peel on the large black areas.  Not sure how you're painting, but here's what I do: build up a fairly thick layer of clear coat by applying a few thin coats one at a time, keep sanding to keep it flat, start using finer and finer sand paper, then finish it off with some rubbing compound and a rag.  I use a 3M auto polishing compound with recycled cotton shirt rags.  I can check exactly what grits of sandpaper and the name of the compound if you're interested.
CoryBee
  • Bopity Boopy
« Reply #37 on: December 18, 2012, 09:34:27 pm »
Thanks, and.... what do you mean by orange peel?
rablack97
« Reply #38 on: December 18, 2012, 10:14:02 pm »
Orange peel is the texture you get when you paint and don't sand the first coat properly.  It causes the paint to build up and it looks like the outside of an orange.
For your selling rigs what your doing is fine, as getting rid of orange peel and getting a mirror/smooth finish is a ---smurfette---....
For giggles.....
Prime, let dry, and sand, then prime again, and sand with a finer grit sand paper.....get you some tack cloth and wipe it clean....
It should feel really smooth to the touch....first coats should be light, then cut it back with a finer grit sandpaper, then paint again and if you do it right no orange peel......Let dry
Then hit it with like 4 or 5 coats of clear, wet sand, and then you can hit it with a compound, swirl x and then buff with wax......mirror like results....
This is sick....
http://forum.arcadecontrols.com/index.php/topic,94891.160.html
« Last Edit: December 18, 2012, 10:17:30 pm by rablack97 »
CoryBee
  • Bopity Boopy
« Reply #39 on: December 18, 2012, 10:24:15 pm »
MY GOD MAN, sounds so time consuming.
I saved that to a text file for later usage, thanks a million.
On the subject of marquee art, can any of you guys that have better ideas than I edit this .psd file with something more fitting to the CP?
Everything I find isn't resizing right and is becoming a pain cause I want to get it to the customer. He already said he liked what I had on it but if I put something better I am sure he wont mind.
« Last Edit: December 18, 2012, 10:26:15 pm by CoryBee »
