Author Topic: Trackball Mounting  (Read 11754 times)
xads308
  • Last login:July 22, 2013, 04:46:12 pm
  • He's on the dance floor.
Trackball Mounting
« on: December 03, 2012, 04:36:40 pm »
Hey there, I bought one of these kinds of trackballs a little while ago (go ahead, make fun of me for going the cheap route...), and I was wondering if there were a mounting plate I could use for it, maybe something by Happ or otherwise. Any help would be appreciated; thanks!
yaksplat
    • Random Projects
Re: Trackball Mounting
« Reply #1 on: December 04, 2012, 11:13:13 pm »
What size is that?
http://yaksplat.wordpress.com
xads308
« Reply #2 on: December 05, 2012, 12:02:24 am »
2 1/4". I may have found someone to make a custom plate for it, but if you can find one somewhere else, I'd be much obliged!
Unstupid
« Reply #3 on: December 05, 2012, 05:32:40 am »
What size is that?
Paradise carries that TB!
maffewl
  • Last login:June 05, 2020, 03:11:44 pm
« Reply #4 on: December 05, 2012, 10:34:30 am »
I had the same problem.  Here is an easy fix that I came up with that works great.  It only costs maybe 4 bucks at Lowes.  Mine is mounted using (4) 1.5" L-brackets holding the wood and (4) 1" L-brackets holding the trackball.  I used a "machine" screw from Lowes that threaded perfectly into the trackball mounting holes (I took the trackball to Lowes to figure out which one would work, sorry I don't remember the size now).  Anyhow, it's sturdy and if I need to remove it, all I have to do is unscrew the wood (1.5") L-brackets and everything is removable without messing with the top side of the control panel.  See the pics below.
PS, the screw is shown for presentation purposes, it screws all the way down to the trackball for a secure hold.  Just wanted to show how the trackball looked in the "jig" with the screws/bolts I purchased.
(Please ignore the test coat of paint  :lol)
« Last Edit: December 05, 2012, 10:37:11 am by maffewl »
maffewl
« Reply #5 on: December 05, 2012, 10:42:02 am »
Also, here is a pic of before I figured out to use the L-brackets to hold the wood.  :angry:  Everything else is the same in this pic except that I glued the wood down.  Great idea unless you ever need to remove the trackball from the bottom of the control panel.  (I can't remove from the top because of the plexi cut to the trackball size so I would have to undo all buttons, etc.)  So this forced me to come up with the 1.5" L-brackets holding the wood on the sides so everything can be removed from the bottom.  The final solution is to do it like the painted control panel in the previous post, but this may be a little easier to see what was done.  Cheers!
Unstupid
« Reply #6 on: December 05, 2012, 08:05:42 pm »
What size is that?
Wow..... What a stupid answer.... that's why I shouldn't post at 1:30 am half asleep!  :P
yaksplat
    • Random Projects
« Reply #7 on: December 06, 2012, 07:45:36 am »
I was willing to let it go  ;D
Hawkeye71
  • Last login:July 16, 2018, 03:39:54 pm
« Reply #8 on: February 25, 2017, 02:11:31 pm »
Over 4 years later but I'm going to say thanks for this tip. I'm in mid control panel build and I also have this model of trackball to install. I will give this a try.
The malarkey one has to go through to get an acceptable amount of ball above the panels horizon is ridiculous. I've dug a square trench of course but the panel is now so wafer thin above to bolt onto I wonder how fragile it will be.
Seems the optional mounting plate shouldn't be optional but part of the kit as standard.
I'm going to gamble and go without ordering  the plate as it is a little ugly on top but, my word it's a bad design.
JDFan
« Reply #9 on: February 25, 2017, 02:52:44 pm »
Easiest way I've found is to use one of the Metal control panels for about $35 shipped -  ( http://www.ebay.com/itm/Multicade-Control-Panel-w-2-1-4-IN-trackball-hole-f-Pacman-Galaga-Arcades-More-/331157615590?hash=item4d1a8833e6:g:LNUAAOSw5dNWjn8- )
Hawkeye71
« Reply #10 on: February 26, 2017, 02:50:38 am »
Oh, didn't know they made those.
But my wooden box has already been built
I think.....Above underneath supports idea  for strength but I think I'm going to have to bolt straight onto my 2mm plexi with artwork covering the horror. Wood and plexi just doesn't give enough exposed trackball otherwise. I'd rather 4 studs exposed  than an entire mounting panel.
Sorry, veering away from woodwork but, I see people generally bolt these in in a diamond fashion. Does it matter which way a trackball sits? I assumed the side that has all the cables coming out is the down direction? Or can that all be configured later?
« Last Edit: February 26, 2017, 02:52:25 am by Hawkeye71 »
  • Last login:Today at 02:45:09 pm
« Reply #11 on: February 26, 2017, 05:26:45 am »
Yes, it matters which way the trackball sits.
The two rollers with the encoder wheels must be aligned with the desired X-axis (the roller perpendicular to the screen) and Y-axis. (the roller parallel to the screen)
This trackball is a PS/2 model (square mount pattern) and based on this thread showing another shallow-mount method, it looks like the cable exits the case away from the screen.
The metal panel above is for a Happ 2-1/4" trackball (diamond mount pattern) and IIRC the wires come off the lower left corner.
You can see the X-axis roller pulled out in this diagram.
If you have to turn this trackball 90, 180, or 270 degrees to get it to fit, you can change the data line connections to your optical encoder to swap directions/axes as needed.
Your best bet is to get the trackball you want and test it before you mount it to the panel.
EDIT: Updated KADE forum URL.
« Last Edit: December 04, 2019, 02:36:21 pm by PL1 »
Hawkeye71
« Reply #12 on: February 26, 2017, 05:56:57 am »
Thank you PL.
Hmm, remove the  cover completely. And there was me mulling over whether I should file the cover down.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #13 on: March 27, 2017, 10:19:10 pm »
I installed mine upside down which didnt matter because i changed the wiring on the ipac2 :)
Hawkeye71
« Reply #14 on: March 28, 2017, 07:56:35 am »
How did you wire it in?
equlizer
« Reply #15 on: March 31, 2017, 10:23:26 pm »
I wired mine to an ipac2  :afro:
Hawkeye71
« Reply #16 on: April 01, 2017, 03:17:49 am »
yes but what wires where? I take it the second cable with the wires for the buttons not essential?
equlizer
« Reply #17 on: April 03, 2017, 07:20:08 pm »
The mouse buttons?  I dont use them and they are not needed unless you want to not use a regular mouse.  My keyboard and mouse stay hidden away on a pull out tray.
bperkins01
« Reply #18 on: August 29, 2017, 05:02:22 pm »
I know this is an older thread - but I'm facing the same decision right now..  How do I get my 2 1/4" trackball in a plexi covered CP with the proper exposure..
I'm planning on a undermount of the Happ ball and use an overlay under 1/16" Plexi to fit properly...
If I had a 3d Printer - I bet I could design a new *top* for the Happ trackball that resembles the Ultimarc trackball that allows for 3/4" panels..
Wonder if there is a market for that ...
