Author Topic: Total newbie when it come sto building a cabinet......  (Read 2797 times)
RyoriNoTetsujin
  • Last login:March 23, 2024, 03:55:45 pm
Re: Total newbie when it come sto building a cabinet......
« Reply #1 on: December 02, 2012, 01:29:40 pm »
How are you planning on getting those parts to interface with your xbox?
Hacking a controller?
Buying an interface (such as an iPac + the associated console adapter?)
  • Last login:Yesterday at 07:42:11 pm
« Reply #2 on: December 02, 2012, 01:33:40 pm »
Looks like a good start.
What are you using for your encoder? Hacked controllers or planning to drop in several of the new KADEs once they released?
Have you made a list of admin button functions? (start, back, exit, etc.)
Also, I assume on the rainbow 16-pack of wires that you are getting several of them:
2 joysticks - 8 wires
12 player buttons - 12 wires
other buttons - ?
To see if you've forgotten anything else, you might want to check out Degenatrons' XBox build here.  It includes videos and lots of details.
NewToBuilding
  • Last login:May 14, 2013, 07:41:19 pm
« Reply #3 on: December 02, 2012, 01:47:17 pm »
Sorry, I should have given more information.
I bought a KADE interface. It's not out yet, so I'm slowly buying the parts I'll need :)
NewToBuilding
« Reply #4 on: December 02, 2012, 01:50:00 pm »
other buttons - ?
You're spot on about the KADE :D. That's one sparked my interest to finally get going. I've always wanted to build one, but I suck at soldering and stuff. I saw on another website, the KADE project, and bought two of them.
I was told to buy those cables by someone on the KADE team. Do I need more than that?
I will definitely check out Degenatrons' XBox build. Thanks for the help :)
NewToBuilding
« Reply #5 on: December 02, 2012, 01:57:09 pm »
Sorry about all the typos and grammar errors. I shouldn't type replies without my glasses on  :-\
I was trying to say that the KADE really got my motivation going when I saw it. I suck at soldering and this seems simple enough for someone like me.
« Reply #6 on: December 02, 2012, 02:26:22 pm »
2 of the 16-pack QD wires and 1 of the 30-connector daisy-chain grounds should be fine for wiring the controls on a 2P bartop.
I recommended reading up on Jon's and other builds so you can see some of the little things that people forget like marquee retainers, cooling fans, volume controls, monitor power on/off, etc.
It's a good way to uncover the things you don't know that you don't know -- the unknown unknowns.
BTW Floriske.nl is in the process of doing a similar build using KADE prototypes.
NewToBuilding
« Reply #7 on: December 02, 2012, 04:00:04 pm »
Awesome! Thank you very much for the help and links!
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #8 on: December 02, 2012, 05:14:04 pm »
The KADE is missing one thing.  Rotary control!  Then it would be perfect and i would get one.
degenatrons
« Reply #9 on: December 04, 2012, 06:37:59 pm »
other buttons - ?
That was me who recommended you get 2 of those cables :D
Another option is to re-purpose the cable from an old (or broken) xbox controller and attach a USB female port to end.
Yet another option is to use a regular USB extension cable and wire one end to the wires behind the controller port.  If you're de-casing your xbox then this is a cheap solution.
The wiring of both options is super easy.
Those cables are cheap to just go buy.  Often,  I don't have the patience to wait for parts.
degenatrons
« Reply #10 on: December 04, 2012, 06:48:09 pm »
Rotary support is a feature we really want to see on KADE and we'll be experimenting with trackball support soon.
We just ordered some trackballs to play around with,  including a Happ Arcade Trackball (with AMOA Harness) and a Sparkfun Trackball (with PS/2 plug).
Big shout out to Victor for contributing these items to our KickStarter project.
