Author Topic: GroovyMAME/GroovyUME 0.149 SwitchRes v0.014b  (Read 152593 times)
rCadeGaming
  • Just call me Rob!
Re: GroovyMAME/GroovyUME 0.147u3 SwitchRes v0.014
« Reply #80 on: December 07, 2012, 06:22:38 pm »
Emuola, I don't think you understand what the different modes mean, and the significance of running native resolutions.  It sounds like someone gave you some advice that... I won't say it's bad advice, but they were just trying to tell the easiest thing to do, with no regard to what would actually give you a good picture and make the most of your monitor.
Basically, one of the main points of GroovyMAME is to help run these games in their native resolution, meaning the resolution they originally ran in the arcade.  90% of games in MAME originally ran in resolutions around 320x240, meaning they ran in 15kHz resolutions.
15kHz = anything around 320x240 progressive (240p) OR 640x480 interlaced (480i)
25kHz = anything around 512x384 progressive
31kHz = anything around 640x480 progressive (480p)
If you run these 15kHz games in native res they'll be sharp, and they will have authentic scanlines; they'll really look good.  If you run them in 31kHz they have to be upscaled (stretched out to fit a larger resolution), they'll probably be either too blurry or too sharp, and the scanlines will be gone; they won't look nearly as good.
Now games that are actually meant for 31kHz will look great in 31kHZ.  Same thing with 25kHz.  Everything generally looks best in its native resolution.
The whole point of a Tri-Sync is to be able to display all these different resolutions.  I'm sure you paid a good amount of money for that thing, so you should put some work into getting a good picture out of it.  If you're just using it for 31kHz and scaling everything lower up, it's not much better than a computer monitor.
emuola
  • Last login:June 15, 2017, 02:19:54 am
« Reply #81 on: December 08, 2012, 02:21:32 am »
The whole point of a Tri-Sync is to be able to display all these different resolutions.  I'm sure you paid a good amount of money for that thing, so you should put some work into getting a good pictre out of it.  If you're just using it for 31kHz and scaling everything lower up, it's not much better than a computer monitor.
Thanks for the explanation rCadeGaming :) Actually, I understand the modes, but I was told that I'd get trouble with the monitor settings (h-position/v-position, v-size/h-size, the physical control panel), when mame switched to one mode to another. I was also told that getting all the modes to be displayed perfectly I'd need to manually fiddle with the modelines *a lot*. Thus I was told to scale everything to vga -> one monitor setting "fits all" :) But now, as GA seems to be very smart with the reolutions, I'm very happy to use all three modes and the native resolutions :) Woohoo  :cheers:
I'm just about to get things ready for hooking everything together. Cab is pretty much ready, I just need someone to help me to hook up the m3129 into the cab. That beast is *heavy* :D
Thank you guys fo all your help so far  :notworthy:
  • Last login:March 12, 2026, 04:46:23 am
« Reply #82 on: December 10, 2012, 02:02:35 pm »
If GM can control settings through Powerstrip, couldn't I program my front-end to do the same though?  I won't need to with GroovyMAME, but I may need to set timing values before launching a PC game.
Of course, that's perfectly possible. If you check the GM's source, there's a file named pstrip.c, that can be used as a library to interface with Powerstrip with little or no change.
Monkee
  • Last login:June 08, 2025, 10:45:43 am
« Reply #83 on: December 10, 2012, 04:41:49 pm »
Hi Calamity,
Thanks a lot for the good work that you've done.  :)
I still have one suggestion/question: concerning the ones that use GroovyMame on a flat screen or videoprojector, is it possible to reproduce something like that only with software :  http://shoryuken.com/forum/index.php?threads/t-slg-toodles-scanline-generator-authentic-retro-look-from-your-modern-flatscreen.145407/ because it's apparently a huge improvement in term of confort !
Thanks a lot.
rCadeGaming
  • Just call me Rob!
« Reply #84 on: December 10, 2012, 05:45:38 pm »
Thanks, I'll start there.
cloaknite
  • Last login:October 16, 2015, 12:31:06 pm
« Reply #85 on: December 11, 2012, 05:23:44 am »
Hi there, my crt is an hantarex polo/2 28 star, can I use the polo preset or it's better to use the arcade_15_25?
Thanks a lot!
« Last Edit: December 11, 2012, 07:12:07 pm by cloaknite »
tyson171
  • Last login:December 07, 2022, 09:34:22 pm
« Reply #86 on: December 15, 2012, 01:07:07 pm »
Anyone use a wells gardner 25k7191?  Is the wells 7131, 7000 preset the best setting for this monitor, or just use the standard arcade 15hz preset?
Monkee
« Reply #87 on: December 18, 2012, 08:40:27 pm »
Hi guys,
I plan to buy some wiimote to play gun games on groovymame and I'd like to ask you some informations to be sure to make the right choice:
Do we need a bluetooth dongle in the pc and a sensor bar on the tv to use this fonction ?
Do the  Wii MotionPlus/ Wii Remote Plus works on this system ?
Did anyone tried to see if the BigBen Walther P99 replica gun that incorporates the wiimote system inside(https://www.amazon.co.uk/bigben-BigBen-Walther-P99-Wii/dp/B0041NWAT6) or even the Guncon3 are working ?
Thanks a lot.
Monkee
« Last Edit: December 18, 2012, 08:42:24 pm by Monkee »
« Reply #88 on: December 19, 2012, 05:10:06 pm »
Are you planning to use Windows or Linux? The wiimote support is for the Linux build, I think you need extra software to achieve that in Windows (never tested myself).
Under Windows, you can use hlsl to achieve 'realistic' CRT emulation on LCDs. Google 'hlsl' and MAME, there's plenty of info.
Monkee
« Reply #89 on: December 19, 2012, 07:35:04 pm »
Thanks Calamity !
I'm using Linux for the moment so I will ask directly on the linux part if it's linked to it, sorry.  :-\
tyson171
« Reply #90 on: December 20, 2012, 08:50:16 pm »
Calamity,
I just want to say a quick thanks for all the hard work you and anyone has put into GroovyMame!  It truly is a great piece of software and provides unmatched results when it comes to picture quality!  Thanks again and happy holidays M8!
(ps, it is also extremely easy to setup!  I used to spend hours trying to fine tune my old setups!)
lettuce
  • Make It So!
« Reply #91 on: December 22, 2012, 06:00:13 pm »
Remind me what ini settings i need to set if im using a LCD display?
« Reply #92 on: December 23, 2012, 10:26:46 am »
Calamity,
Hi tyson171,
Many thanks for your comments, specially for the remarked parted.
« Reply #93 on: December 23, 2012, 10:33:08 am »
It's easier than before. You just need to set the 'monitor' option to 'lcd'
Then, if you're using Powerstrip, enable the 'powerstrip' option.
Finally, define the range your monitor can actually refresh, e.g.:
-lcd_range 57.50-61.00
lettuce
  • Make It So!
« Reply #94 on: December 23, 2012, 11:20:36 am »
where do i need to place the, refresh value for my monitor in the mame.ini file?
« Reply #95 on: December 23, 2012, 11:21:50 am »
Of course.
lettuce
  • Make It So!
« Reply #96 on: December 23, 2012, 11:24:37 am »
Do i need powerstrip installed, or can you get away without using it. Any ideas if theres a program that tells you what actual refresh rate your monitor supports? I have a DELL 2405FPW, im guessing its just 50-60hz
« Reply #97 on: December 23, 2012, 11:51:41 am »
You can get away without PowerStrip, but that will force all games to run at 60 Hz. Your monitor may probably support whatever refresh but the key question is if it's updating the panel at the input refresh or if it's converting it internally to 60 Hz. You can use Juddertest in combination with Powerstrip to find your monitor's refresh range.
My experience with the Dell U3011 is that it preserves the original refresh for 58-61 Hz, anything lower is converted to 60 Hz. However Powerstrip is still useful here at least for games that are not exactly 60 Hz but are inside the 58-61 Hz range (many, many games), instead of forcing them to run at 60 Hz. Moreover, a game like donpachi that runs at 57.55 is not so bad when forced to 58 Hz than when forced to 60.
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #98 on: December 28, 2012, 04:15:30 am »
A friend of mine got this error whenever he tries to start a rom:
Exception at EIP=01CE9124 (not found): ACCESS VIOLATION while attempting to write memory at.......
He is using groovymame-0.147u4 32bit self-compiled on windows (using the new official toolchain).
Earth could be the hell of another world
« Reply #99 on: December 30, 2012, 05:45:50 pm »
Hi Ansa, just to double check, did he test with our provided builds? Same crash?
Ansa89
« Reply #100 on: December 31, 2012, 05:22:27 am »
He can't test official build because there is no "groovymame-0.147u4" (at least I can't find it here).
« Reply #101 on: January 01, 2013, 04:19:16 pm »
Hi Ansa89, the other day I built a binary based on v0.147u4 with the groovy patch applied and it worked flawlesly here (not available in the download site). That type of crash seems to point to some problem when applying the patches, I cannot be sure, anyway.
dgame
  • I am no Jedi
« Reply #102 on: January 01, 2013, 11:00:57 pm »
I made a groovymame-0.147u4 and encountered a similar error.
The solution is to move/delete the NVRAM and/or CFG files of the offending ROM and let MAME rebuild them.
Try it and let us know.
krick
  • Gotta have blue hair.
« Reply #103 on: January 02, 2013, 10:17:30 am »
I just wanted to comment that Pac-Man runs flawlessly with the new GroovyMAME.  It looks great, the sound is perfect, the speed seems correct.  I wasn't able to get it running this good with the older version of GroovyMAME.  Namely, the sound was always off because the game was running slower to sync with the video.   What changed?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
« Reply #104 on: January 02, 2013, 11:02:26 am »
It's just that now triplebuffering is automatically triggered when the refresh difference if higher than specified by the -syncrefresh_tolerance option. As this is set to 2.0 Hz by default, it means that for 288-line resolutions, which usually won't run higher than 52-54 Hz on arcade monitors, -syncrefresh is turned off and -triplebuffer is used instead. This is great for non scrolling games like pacman. You can play with the -syncrefresh_tolerance option in order to decide how off the refresh must be for enabling this behaviour.
« Last Edit: January 02, 2013, 11:19:06 am by Calamity »
matrigs
  • Last login:August 01, 2013, 06:07:13 pm
« Reply #105 on: January 03, 2013, 02:24:29 pm »
Sorry if this is a dumb question - but is the Groovyarcade LiveCD iso to be burned simply to cd and booted? It doesn't really want to when i pick Cd-Rom boot in iso.
EDIT: Sorry, being a numpty. Works now.
To still usefully use this post:
I want to use Groovymame with my Sega Naomi Sanwa 29e31s VGA monitor. It is 31khz only. Should i use the standard "CRT 31khz" settings or these custom settings which i found on retrovicio.org:
SANWA 29E31S
(mame.ini)
monitor_specs0 31000-32000, 55-70, 1.60, 3.04, 3.22, 0.44, 0.09, 1.04, 0, 0, 576, 768
What settings would i have to use to make Groovymame linedouble 224p games without applying any stretching, filling the missing lines blank? In a normal Mame build i would set the output resolution to 640x480 and use the options "Switch resolutions to fit" and "Enforce aspect ratio" and it would do exactly this.
With games using very unorthodox resolutions like Ketsui - 448x224 i would additionally have to change the output resolution to 1024x480 to make this work.
Is this achievable in Groovymame, just also with the right timings? In case of Ketsui - is it possible in Groovymame (it isn't in other Mame builds) to only linedouble and not pixel double the resolution to 448x448 to?
Thanks in advance
« Last Edit: January 03, 2013, 02:56:05 pm by matrigs »
Ansa89
« Reply #106 on: January 12, 2013, 05:18:44 am »
Patch updated for MAME 0.148.
Please test it before upload on the official site.
krick
« Reply #107 on: January 13, 2013, 01:03:14 am »
It seems to work OK so far.  Do you know if any of the recent HLSL changes in baseline mame might have impacted the GroovyMAME code?
Hantarex Polo 15KHz
Ansa89
« Reply #108 on: January 13, 2013, 05:20:11 am »
I'm sorry, I don't know.
The only thing I can say is that digging into mame source, trying to update the groovymame patch, I didn't see any relevant change (speaking of code near the patch hunks); however Calamity probably have a better answer for your question.
Ansa89
« Reply #109 on: January 14, 2013, 06:38:20 am »
The error persists.
@dgame: did you use the new toolchain to compile it?
dgame
  • I am no Jedi
« Reply #110 on: January 14, 2013, 10:22:02 am »
Yes I am using the new toolchain and updated to GM 148 using your patch above and all is well.
What game is giving the problem?
Ansa89
« Reply #111 on: January 14, 2013, 10:38:02 am »
He tried with shinobi, mk, gng, snow bros and sf2.
« Reply #112 on: January 14, 2013, 11:08:22 am »
Hi Ansa89, I would need a full log, disabling the -multithreading option, to have a better idea of where the problem is arising.
Ansa89
« Reply #113 on: January 15, 2013, 10:00:56 am »
Here is the log.
« Reply #114 on: January 15, 2013, 11:23:43 am »
Thanks Ansa. For some reason he has the -modeline option disabled. That shouldn't cause GM to crash (it did in older versions), but I wonder if there's still some bug related to it. First tell him to enable the -modeline option. Apart from that the custom modelines are not being read, this is probably because of the order the displays are listed. How many video cards are there in that system?
Monkee
« Reply #115 on: January 15, 2013, 01:55:37 pm »
Hi Calamity,
I plan to use GroovyMame on an arcadebox with a old CRT TV but also sometime with a LCD. How may I get original-31khz games to work on their original frequencies on LCD ?
Thanks a lot.
Monkee
« Reply #116 on: January 15, 2013, 05:43:32 pm »
Hi Calamity,
Thanks a lot.
Monkee
You'll need to change the monitor type in mame.ini, either by using a defined preset or custom crt_ranges. Usually you won't send a 31 kHz signal to a LCD, but it's native resolution (that may be way far from 31 kHz). There is a preset named 'lcd' for this. But if you're using Linux it's often better to use the vesa_*** presets.
Monkee
« Reply #117 on: January 16, 2013, 04:44:52 pm »
Thanks a lot !  :)
Ansa89
« Reply #118 on: January 17, 2013, 03:04:34 am »
He said, he never used the "-modeline" option either with previous versions, but he will try to enable it.
The system has two video cards:
- ati 9250 pci (not pci-e) set as "primary" into bios (this is only used to prevent the boot phase to show up)
- secondary video card used for everything else
Ansa89
« Reply #119 on: January 17, 2013, 05:23:38 am »
The problem persists even with "-modeline" option enabled.
