Author Topic: Mala and Arcade Jukebox--getting Mala to launch others-solved!  (Read 2311 times)
diamondz
  • Last login:January 27, 2013, 11:40:32 pm
« on: November 08, 2012, 01:06:12 pm »
I am trying to get Mala to launch Arcade Juke box. I have it setup as other emu.
I have pointed to the exe.    located in a Juke folder in the mala folder
I have pointed to the mp3 folder   located in the juke folder.  I have created a blank text named aj8.txt and it is inside the juke folder.
i have the commnad @ %rom% as directed.
I saved but i still dont see the arcade as an option in mala.
Do i have to set it up in mala tree?  are there other options that need seeting up. I tried following the directions and that's as far as they go.
The arcade plays fine without going through mala.
if someone could let me know what i am doing wrong i would appreciate it.
Solved.. I followed the instructions here... http://forum.arcadecontrols.com/index.php/board,43.0.html
« Last Edit: November 08, 2012, 11:30:11 pm by diamondz »
