Author Topic: 5'14 Drive Panel for 2 Nes/Snes/N64 controllers  (Read 3152 times)
ice^storm
  • Newbie
  • Last login:October 26, 2003, 04:03:46 am
« on: October 25, 2003, 11:30:11 pm »
Hello All
Im designing a micro home theather Pc with 2 5'14 drives, the left one will have nes snes and n64 inputs (nes and snes via DirectPad Pro and 2 n64 via adaptoids) and a dvd rom on the right running the Via M10000, i was wondering however if anyone knows if i could just wire the 2 snes controllers into the 3rd and 4th wires for the nes diagram, any help will be appreciated..
http://www.auspcmarket.com.au/show_product_info.php?code=CA-LLPC9300&category_id=40 (Case)
http://www.arcadecontrols.com/Mirrors/www.ziplabel.com/dpadpro/nes.html (Direct Pad Pro)
Thanks,
ice^storm
« Last Edit: October 26, 2003, 01:43:32 pm by tom61 »
J_K_M_A_N
Re:5'14 Drive Panel for 2 Nes/Snes/N64 controllers
« Reply #1 on: October 29, 2003, 12:51:49 pm »
I believe the SNES and NES pads are very similar. I also believe I read that you can mix and match SNES pads and NES pads on the 1 parallel adaptor. Wire NES pad 1 to db25-10 and NES pad 2 to db25-12 and SNES pad 1 to db25-13 and SNES pad 2 to db25-15. The you just have to set up controller 3 and 4 to use the SNES drivers and controller 1 and 2 to use the NES drivers. (In the game controller panel) Should work like a champ. (Just so you know, I haven't tried it myself, but like I said, I believe I read it somewhere about the mixing of the 2.) Good luck.
J_K_M_A_N
