Author Topic: Rowe r-81 adding records  (Read 1768 times)
jeepers128
  • Last login:September 06, 2013, 09:23:27 am
« on: November 01, 2012, 10:09:53 pm »
Is there a way to add records the jukebox? It seems like the records hit the mechanical system and there are hard to get out.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe r-81 adding records
« Reply #1 on: November 07, 2012, 11:29:47 am »
Hello Jeepers128,
If you put the service switch into the service position and then press the scan switch, you can scan the mechanism around to the record location you want.
Regards
Alan
Alan Hood
ami-man
UK
jeepers128
« Reply #2 on: November 07, 2012, 09:41:11 pm »
Is there any way to have it place the record and then pick the new record and put it away?
