Author Topic: Dongle not Recognized / PGA Golf Team Challenge  (Read 4586 times)
Mooner4
  • Last login:November 02, 2012, 06:00:55 pm
« on: November 01, 2012, 12:25:48 pm »
I have a PGA Golf Team Challenge arcade game that I obtained from a friend.  It was not working.  I re-installed all CDs (version 3.x).  The install seemed to go perfectly (after I replaced the Power Supply).  But the game still boots up and says that it does not recognize the dongle (or it is missing).
I bought a new dongle and VR recommended that I reinstall - which I did - and I still get the same error message.  They also stated that new dongle they sent may require version 4.x software instead of 3.x software.  (may not be compatible with version 3.x software)
I already reset the motherboard settings to "load from default" as VR suggested.
Does anyone have any ideas on other items to configure or check to verify that the dongle is working?  I do have an IT friend at work that can boot up Linux - just to see if it shows up in the linux device list.   But are there any other tools to check the dongle or configure it?
  • Last login:Yesterday at 10:26:35 am
Re: Dongle not Recognized / PGA Golf Team Challenge
« Reply #1 on: November 01, 2012, 02:39:54 pm »
Dongle plug into USB?  Try plugging it into a different USB port.
Mooner4
« Reply #2 on: November 02, 2012, 11:13:06 am »
No it does plug into a USB. I think they sent me the 4.0 dongle and it does not match my 3.0 software. Global told me to send it back and they would replace it with the 3.0. However they told me that the 4.0 was a upgrade and expensive (for the dongle). Does anyone know what that upgrade achieves?
ed12
« Reply #3 on: November 02, 2012, 12:51:50 pm »
hi
1=to start with the dongle plug's into the parral port of the putter
then u take a cable from 1 usb port to the :I/O: card
2=ver4 is an up-grade and will not work with 3..
3=the code is written in both linux and window's >XPE<
so u can clearly c the call's
4=it is possiable to shut the dongle down.>LOOK FOR THE CALL,INCULDING THE NESSARY DLL'S<
5=i take it u are usa ?
what i just told u will get u started,gobal vr no longer support's pga golf,the engerring team was disbanned 10 year's ago
if u require detailed setup .ins
try this
1=set cdrom as first
2=set harddrive >0< as second
3=turn floopy seek off
4=disable floopy
if u care to disamble the code set,u will need a few tool's
they list as follow's
1=window's >XPE< disambler,so u can see the .EXE
2=hercule's disambler,with this u cannot do it on a win7 box >MUST BE 98/XP<,
3=a through know of window's
ed
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #4 on: November 05, 2012, 02:57:34 pm »
I think that version 3 is "Challenge" and version 4 is "Team Challenge" which was the latest release of the series unless you want to count the "ALL ACCESS" pass.  I could be wrong but I remember my old "Challenge" disks being version 3 I believe.  How much were you charged for version 3?  On the dongle does it say "Challenge" or "Team Challenge?"  My dongles do not go in the typical USB slots as they have pin layouts.
« Last Edit: November 05, 2012, 02:59:14 pm by stpcore »
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
ed12
« Reply #5 on: November 05, 2012, 04:35:15 pm »
hi
i thought i made this clear
all dongle's hook into the parall port of the mobo
if it is tied to the usb port then it is a hack
and i CANNOT help the op..---smurfy--- i know
but it is the way it is
if it is tied into the parall port
then i CAN help
ed
stpcore
« Reply #6 on: November 05, 2012, 04:54:14 pm »
The OP stated that he purchased a dongle from Global VR so I don't think that it's a hack.  With that being said I have never seen a dongle that plugged into a USB port for PGA.  So unless Global VR has some new way to connect a dongle I think that there is a misunderstanding somewhere.  My dongles plug into the parallel port...I've never seen a USB dongle for this game.
yukonblaze
  • Last login:February 16, 2023, 11:32:48 am
« Reply #7 on: November 29, 2012, 03:39:03 pm »
I know what you are talking about as my all access came with a usb key.  I am unsure if that was the dongle or not.  I havent looked in the back of my machine as I am at work today.  I believe I sent the usb and my dongle to Global VR and the sent back the dongle patched with All Access.  I will lok tomorrow and update ya.
Jason
stpcore
« Reply #8 on: November 29, 2012, 04:16:55 pm »
That would make sense if "All Access Pass" is a USB update or security key (it's the only version I haven't played).  From what I've experienced all other versions are using a dongle that plugs into the printer port on the back of the computer.
yukonblaze
« Reply #9 on: November 29, 2012, 05:02:37 pm »
I even looked at the team challenge manual online and it said that a usb dongle was used.  My all access usb was found in game I bought at auction.called global vr and the said they would reprogram it if I sent it to them, so that was a no brainer.
Jason
ed12
« Reply #10 on: November 29, 2012, 09:31:36 pm »
hi
what u have is an all access point usb stick
the dongle hook's to the par port of the mobo >it carry's< your box :key: along with the o/s rev/date/verison
that is what the kill cmd i posted the other night is for
if the usb all access is  not working then there is a few step's here
1=is your i/o card pluged into the main mobo usb ?
2=do u have a usb-2 card ? if so is it plugged in there instead ?
3=where is your player-card reader plugged into? > it should be usb also<
4=have u chked to make sure all usb's are working ?
5=did u make the i/o card  is pluged into the power supply ?
ed
ed12
« Reply #11 on: November 29, 2012, 10:18:14 pm »
hi
allow me to clraify something here
the all acess point has nothing to do with the dongle
it is for on line gamming
it IS NOT CARRIED THROUGH GOBAL-VR
it is carried through a another company
again it has NOT a thing to do with your key issuie's
your DONGLE problem is exactely what i stated in my last post here
go through the step's i posted
get back to me
i will be happy to more then help u
ed
