Author Topic: Command Mame - Joystick problems  (Read 1404 times)
Bobby115
  • Last login:July 18, 2011, 06:55:13 pm
« on: October 18, 2003, 05:01:47 pm »
Ok.....For some reason I can't get my joysticks to work in command mame. What do I have to do to get this working??
I was also using mamewah but could not get it working through there either?? Is there a config file I need edit??
In windows the joypads show up fine.
Thanks in advance
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
Re:Command Mame - Joystick problems
« Reply #1 on: October 18, 2003, 05:03:56 pm »
I think it's -joy in the commandline?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: October 18, 2003, 06:15:46 pm »
Thanks in advance
For window commandline, you can use either "-joy" or "-joystick".  To make config file, type "mame -cc", which make a mame.ini file; change "joystick 0" to "joystick 1" to enable joysticks from here instead of commandline.
Robin
Knowledge is Power
