Author Topic: What paint to use for MDF?  (Read 2742 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: October 17, 2003, 09:25:24 am »
I mean enamel, latex, etc.
It is for a control-panel-only project and will probably go all black.
Thanks.
"The Manuel"
Wade
  • Last login:Today at 08:21:17 am
  • 80's Child
    • Wade's Gameroom
Re:What paint to use for MDF?
« Reply #1 on: October 17, 2003, 09:31:16 am »
I tried a cheap gloss black oil based and it looked horrible, switched to a black semigloss wall paint and it looked great.  Use a smooth foam roller, you'll be surprised how good the finish can be if you are careful.
Wade
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
« Reply #2 on: October 17, 2003, 11:04:17 am »
Whatever paint you pick, make sure you use primer!
Many people complaining about how their paint jobs turned out didn't use a primer.  Make sure you use one, primer is pretty cheap.  I agree with the roller for applying, I used a normal fine roller, non foam worked good.
I used thick glossy black outdoor paint for my cabinet, it wasn't the stuff to paint over rust, but it was right beside it, and similar to the rustoleum paint.
TheManuel
Thanks, gentlemen. NT
« Reply #3 on: October 17, 2003, 11:15:29 am »
NT
"The Manuel"
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #4 on: October 17, 2003, 11:20:19 am »
How about spray paint? It's more expensive but doesn't it have a better finish?
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #5 on: October 17, 2003, 11:37:39 am »
Most people have a real hard time getting an even finish with spray paint... It takes A LOT longer to paint (you HAVE to do multiple light coats)... It costs A LOT more...
You get the picture... If you've got an airless spray rig or something like that, that could give a great smooth finish, otherwise I'd stick to a brush & roller...
I'm not a freak!...
Oh wait...
Yes I am...
CCM
« Reply #6 on: October 17, 2003, 12:24:46 pm »
I agree with tmasman... I tried spray paint on my first cabinet, and gave up on that idea real quick.  I couldn't get even coverage, and I realized it would take a lifetime!
I then switched to a latex based semi-gloss and a foam roller and it looks great!
mnapuran
  • Last login:December 25, 2003, 12:37:50 am
« Reply #7 on: October 17, 2003, 03:13:51 pm »
Also... as for primer, if you are using MDF I highly recommend using Kilz as your primer.
Mike N
Sasquatch!
  • Last login:March 01, 2010, 04:11:47 pm
  • Toot-Toot!
    • Arcade Paradise
« Reply #8 on: October 17, 2003, 10:47:15 pm »
Why?
Tailgunner
  • Last login:October 06, 2009, 01:21:16 pm
« Reply #9 on: October 18, 2003, 12:11:45 am »
Kilz is a great all around primer. It's preticularly useful on materials that soak up paint like a sponge.
My personal favorite MDF paint would be lacquer.
