Author Topic: Happs 27" Bezel Depth Measurement Needed  (Read 1572 times)
Pixelhugger
  • Last login:March 05, 2026, 11:55:53 pm
« on: October 15, 2003, 08:42:35 pm »
I am drafting my cab plans in 3D and need to get the "depth" measurement of the  Happs 27" plastic bezel (so I can layout the exact monitor position and angle).
What I need is the distance straight down from the surface of the bezel to the edge that contacts the monitor glass.  I understand that it's curved, so the lowest point would be best. (Obviously measuring the length of the beveled edge - as seen in red in the attached jpg - will give me the wrong distance.)
Put another way..if you were to lay a straight edge flat along the surface of the bezel and then measure with another ruler straight down from it to the bottom lip of the bezel...that would be the distance I need.
Any help would be greatly appreciated!
Project mega thread HERE
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
Re:Happs 27" Bezel Depth Measurement Needed
« Reply #1 on: October 15, 2003, 08:45:26 pm »
At the center points it's 1" deep and at the corner points it's 2" plus or minus 1/8"
Pixelhugger
« Reply #2 on: October 15, 2003, 08:49:05 pm »
Excellent. Thanks a million!! Just out of curiosity that was such a fast and exact response- did you already have that info handy or did you measure it? Impressive response time.
MiKman
  • Blah
« Reply #3 on: October 15, 2003, 11:46:18 pm »
I have my cabinet sitting right beside me and the Bezel isn't installed yet. with tape measure handy I just happend to see your plea and measured it up just for you.  We must have been on the board at the exact same time :-)
MiKman
  • Blah
« Reply #4 on: October 15, 2003, 11:49:42 pm »
I actually re-measured it.  And it is 2" at the corners and closer to 1.5" at the centers not 1" at the centers...
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:February 23, 2026, 07:55:20 am
« Reply #5 on: October 16, 2003, 12:10:46 pm »
In the thought that a second look would be helpful...
I measured mine and came up with slightly different measurements.  I laid it face down on a hard tiled floor, and used my carpenter's square to measure from the floor to the curve of the bezel at the midpoints and corners.
The spot you've marked in green I measure at 1-1/8".
The spot in the center point on the shorter edges I measure at 1-1/2".
The corners I measured at 1-7/8".
It's hard to measure because the material doesn't lay flat, it bows as you obviously know.
« Last Edit: October 16, 2003, 12:12:07 pm by saint »
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
Pixelhugger
« Reply #6 on: October 16, 2003, 03:01:37 pm »
Thanks again MiK and Saint. This info is critical to me since I'm drafting blindly, without the bezel or monitor, and as far as I can tell, the rear of the 9200's frame will come extremely close to the back of my cabinet. Since the cabinet's depth is already questionably *deep* I really want to avoid adding any extra to it. This will help me get my monitor placement right with minimum (hopefully no) modification to the back.
I really appreciate you guys doing this for me.  :) Oscar sold the cab his file was based on so it wasn't available to get the additional numbers.
