Author Topic: Anyone using a ps2 in there cab?  (Read 3806 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: October 13, 2003, 02:31:43 pm »
just wondering if ps2 with guncon would work on a wg d9200 27 inch monitor and if you would hook up the video on the guns to the video on the radeon 7500 aiw card
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Anyone using a ps2 in there cab?
« Reply #1 on: October 13, 2003, 07:58:45 pm »
I play a PS2 in a cab, with guncon2's just fine.  My monitor is std res arcade.   The d9200 can do std res just fine, so it will work.
As for that last part, if you are infering that you want to run a PS2 through a computer using this radeon card on your d9200, then guncon2 games will not work.
Shieldwolf
  • SpearShield.com
« Reply #2 on: October 13, 2003, 08:09:55 pm »
Dave how do you run a ps2 to your monitor? or what do you hook up the guns to?
Dave_K.
    • Arcade Fever
« Reply #3 on: October 13, 2003, 08:14:03 pm »
I hooked up my ps2 to the arcade monitor via a hacked scart cable (read the Game Consoles faq http://www.arcadecontrols.com/arcade_consoles.shtml).  The Guncon2's are just hooked up like normal (usb) with the s-video connector also going to the scart composite video line for signal timing.
