Author Topic: Extra Small Weecade **Almost Done** - Tons of Photos!  (Read 6255 times)
JdotFite
  • Last login:March 10, 2024, 03:06:41 pm
« on: October 24, 2012, 02:55:17 pm »
Very long time lurker here.  I started my first MAME cabinet build back in 2001, I was 17 at the time.  I have built a full size cabinet, cocktail table and a bartop.  This time around, I wanted to go even smaller.  I really liked Rasmus's Weecade design and decided to go that route.  I will include some photos of my past projects here as well.
The build was based around an HP DVXXXX series laptop.  It had the dreaded GPU overheating issue.  I used the "bake it in the oven" reflow trick to bring it back to life.  I don't have a proper work space, so I was forced to use my kitchen and deck and it was a huge PITA  >:D!  I am happy with the end result.  I decided to keep it clean and minimalistic.  My last bartop had bright busy graphics and I wanted to go the opposite direction this time around.
I will updated with some additional finished photos when I get the chance.
Here is how it looks today:
Progress Photos:
Initial rough mock-ups:
Notebook tear down:
MDF screen bezel made:
Routered Edges:
Maximus Test:
Front and Control Panel cut and test fit:
Profile shot at this point:
Marquee Test:
Top Cut:
Aluminum L and Acrylic Channel cut for marquee:
Real life photoshop: Bondo:
Primer:
1st coat of paint:
2nd coat of paint:
Screen metal bezel paint:
Speaker area cut:
Testing notebook:
Perforated Metal, outlet and switch added:
Coming together:
L channel painted:
Starting Speaker grill area:
The holes were not allowing enough sound through, so I cut one long rectangle and rounded it with my router:
Grill nailed on:
USB Speaker bar ready to be attached:
Testing hardware one last time:
Control panel coming together:
Today:
« Last Edit: October 24, 2012, 02:59:12 pm by JdotFite »
pinballjim
Re: Extra Small Weecade **Almost Done** - Tons of Photos!
« Reply #1 on: October 24, 2012, 03:06:47 pm »
I've always criticized the Wee-Cade for looking like a laptop in a box and then you have to go and put an actual laptop in the box.
That looks really nice, one of the cleaner examples of this design for sure.
CoryBee
  • Bopity Boopy
« Reply #2 on: October 24, 2012, 03:09:44 pm »
I really like this, thanks for sharing!  :applaud:
  • Last login:Yesterday at 10:37:15 am
« Reply #3 on: October 28, 2012, 05:52:31 pm »
Looks good, does it weigh "enough" to play on? :cheers:
koolmoecraig
    • My Intervention
« Reply #4 on: October 28, 2012, 06:58:54 pm »
Nice clean job.  Like Reveen said, is it heavy enough to play without moving around?
fighterfanatic
  • Last login:November 30, 2023, 12:53:13 am
  • Down Right Fierce
« Reply #5 on: October 28, 2012, 07:09:05 pm »
Wow. So fresh and so clean.  :applaud:
