Author Topic: Ultimarc AimTrak / MAME ID Problem (Keeps Changing)  (Read 4098 times)
mrdriver
  • Last login:October 10, 2012, 03:17:08 am
  • As Seen In Project Arcade.
    • Mr Emulator 2
« on: October 09, 2012, 04:34:00 am »
I Emailed Andy regarding this, however, he says the ID is fixed and this is a MAME issue?...
Basically, every time I unplug the AimTrak, reboot PC and plug AimTrak back in again the gun ID changes in MAME (Gun 2, Gun 3, Gun 4 etc.)
Obviously this is a pain in the backside, as I have to reconfigure MAME and all of the light gun games.
I tried making the .cfg folder & files in MAME read only, however, this makes no difference.
Does anyone know how to fix this issue please?  ???
Spend more time with your head in the back of your cabinet rather than actually playing the games?
  • Online Online
  • Last login:Today at 12:54:01 am
Re: Ultimarc AimTrak / MAME ID Problem (Keeps Changing)
« Reply #1 on: October 09, 2012, 07:36:09 am »
Have you looked at drventure's ControllerRemap for Mame utility?
MacGyver says he got his Aimtraks working here in the same thread.
mrdriver
    • Mr Emulator 2
« Reply #2 on: October 09, 2012, 08:09:52 am »
Only problem is that it looks as though you have to run this before starting MAME or frontend. I guess a shortcut in the startup folder would work? Unless it's not quite that simple?
*Edit* Sigh... just read the .pdf that comes with the .exe and it looks a little complicated. Looks like I'll probably just leave the AimTrak connected.
« Last Edit: October 09, 2012, 08:24:03 am by mrdriver »
8BitMonk
« Reply #3 on: October 10, 2012, 05:16:28 pm »
Not sure if this will help you but I've had better luck using ID's 3 and 4 for my AimTraks. If you've only ever tried 1 and 2 maybe try 3 and 4. Mine shows up in MAME as Guns 7 and 8 and they 'stick' between plugging and unplugging.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #4 on: October 12, 2012, 10:42:42 pm »
That sounds like a winner. I bet MAME assigns 1 and 2 to more common devices.
-Banned-
