Author Topic: Computer Modding (cable sleeving)  (Read 1877 times)
t3design
  • Last login:November 25, 2025, 08:51:28 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
« on: October 02, 2012, 06:52:57 pm »
Does anyone here do this? I have decased my computer and want to sleeve all the cables. Not sure if I want to do it myself or have someone do it for me. I'm located in Oklahoma City, OK.
t3
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
  • Last login:Today at 04:03:33 am
Re: Computer Modding (cable sleeving)
« Reply #1 on: October 02, 2012, 07:11:53 pm »
If you go DIY, Walmart has spiral wrap like this in their automotive section IIRC.
Not as pretty as the mesh, but very easy to do and inexpensive.
cigardude
  • Last login:December 20, 2017, 01:29:48 pm
« Reply #2 on: October 03, 2012, 11:00:33 am »
This is something that you should do yourself. If you have some UV lighting, you can get UV reactive sleeving and have it glow! Plenty of online sites with sleeve options.
http://www.xoxide.com/sleevingkits.html
http://www.frozencpu.com/cat/l1/g35/SleevingHeatshrink.html?id=NYMkYr8T
SavannahLion
« Reply #3 on: October 03, 2012, 12:22:50 pm »
When I repaired the wiring in my first vehicle, this is what it had and I absolutely hated it. It serves its purpose but after working with it within the first hour, you'll curse the bastard who invented it. When I did the same work on my 2nd vehicle, I opted for the split tubing. Not as secure in some situations though.
« Reply #4 on: October 03, 2012, 04:31:29 pm »
Fortunately it only took a few minutes to wrap the wires on my PSU.   :lol
The one advantage of the spiral wrap is that you only need 2 zip ties per segment, where the split tubing needs them every 4-6 inches.
I can see how using the spiral wrap on a car -- not being able to easily unplug wires,  the awkward angles, and space limitations could cause you to  :angry: but a PSU is much easier.
