Author Topic: Parallel cable color-to-pin mapping  (Read 12248 times)
unclet
« on: October 10, 2003, 11:51:12 am »
I am using parallel cables as quick disconnects for the controls on my driving cab.  I wanted to determine which colored wires mapped to which pin so I used a continuity tester to map out the color-to-pin mapping.
After cutting the parallel cable wires I had lying around, I noticed I had three different types of cables (18 wire pair, 17 wire pair and 25 individual wires).  I included the color mappings for these wire types below in case anyone else could benefit from my patience  ;D
Note1: I was told that the coloring mapping for parallel cables are not standard, so it depends on the type of cable you are working with for your project, but maybe this can help you out...
Note2: "unused" means the wire is not connected to any pin
Note3: In the (TYPE 1) cable, I believe 18 through 25 are ground so multiple wires mapped to these pins.
TYPE 1) Parallel Cable with 36 wires (18 pairs)
 1 = Brown
 2 = Red
 3 = Orange
 4 = Pink
 5 = Pink/Red
 6 = Pink/Yellow
 7 = Yellow
 8 = Green
 9 = Green/Blue
10 = Blue
11 = LightBlue
12 = LightBlue/Purple
13 = LightBlue/LightGreen
14 = Purple
15 = Grey
16 = Grey/Yellow
17 = White
18 = Brown/White
19 = Red/Black
     Orange/Black
20 = Pink/Black
     Pink/Purple
21 = Pink/White
     Yellow/Black
22 = LightGreen/Red
     Green/Black
23 = LightBlue/Black
     Grey/Black
24 = Blue/White
     LightBlue/Blue
     LightBlue/Green
25 = Grey/Green
     Purple/White
     White/Black
unused = White/Green
         White/Yellow
TYPE 2) Parallel Cable with 34 wires (17 pairs)
 1 = Brown
 2 = Red
 3 = Orange
 4 = Yellow
 5 = Green
 6 = Blue
 7 = Purple
 8 = Grey
 9 = White
10 = Grey/Yellow
11 = LightBlue
12 = Pink
13 = Pink/Orange
14 = LightGreen/Red
15 = White/Yellow
16 = LightBlue/Purple
17 = LightBlue/Green
18 = Brown/White
19 = Red/Black
20 = Yellow/Black
21 = Blue/White
22 = Grey/Black
24 = Grey/Green
25 = Green/Black
unused = White/Black
         Green/Blue(one next to LightGreen/Red wire)
         LightBlue/Blue
         White/Green
         Pink Black
         Purple/White
         Orange/Black
         LightBlue/Yellow
         Pink/White
TYPE 3) Parallel Cable with 25 wires (all individual)
 1 = Black
 2 = Black/White
 3 = Brown
 4 = Brown/White
 5 = Red
 6 = Red/White
 7 = Red/Black
 8 = Orange
 9 = Orange/White
10 = Orange/Black
11 = Pink
12 = Pink/Black
13 = Yellow
14 = Yellow/Black
15 = Green
16 = Green/White
17 = Green/Black
18 = Light Green
19 = Blue
20 = Blue/White
21 = Purple
22 = Purple/White
23 = Grey
24 = Grey/Black
25 = White
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:Parallel cable color-to-pin mapping
« Reply #1 on: October 10, 2003, 07:30:01 pm »
Wow, nice!  this should be added to the FAQ.
If you cut the cable though, all you have to do is match the colors of the wires to connect pin X to pin Y.  Unless you solder a parallel connector into something.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
unclet
« Reply #2 on: October 10, 2003, 08:20:14 pm »
If you were using Type3 cable then of course you would not need to know the actual color mapping since there was only 25 wires and 25 pins so individual each wire would have a corresponding pin.  However, you are using Type1 or Type2 cables then some of the wires do not connect to any pin (or some of the wires go to the same pin) so it is helpful to know exactly which color of wire to use in these cases.
Glad someone finds it useful as well..... :)
