Author Topic: First build .. few questions: CP height, joystick install...  (Read 2039 times)
tcolar
  • Last login:November 29, 2012, 02:05:32 pm
« on: September 24, 2012, 11:49:50 pm »
Hi ... I've meant to build a cabinet since at least 2003, but never got to it but now my kids are getting into (old school) video games too, so it's time.
I've just started my build and have a few questions:
1) What 's a good height for the CP (i'm 6'1) and I rather not have to be hunched too much.
2) I have a couple j sticks ... it seem some moung them with the plate flush over the CP, and other mount it under the CP. It seem under looks nicer since you don't see the plates but i was wondering what the tradeoffs of this are ?
« Last Edit: September 25, 2012, 12:11:14 am by tcolar »
mgb
  • North East, US
Re: First build .. few questions: CP height, joystick install...
« Reply #1 on: September 25, 2012, 12:34:48 am »
hello and welcome.
1) I'm 6.0' and the low end of the slant on my panel is 38". I raised my cab 2.5" to achieve this height and I find it fine.
2) You typically would never want to see your joystick mounting plates. some people top mount them because of short shafts (with wood control panels) but they still cover the mounting plates.
Tiberian Fiend
  • Last login:September 25, 2012, 01:54:16 am
  • Canis tiberius
« Reply #2 on: September 25, 2012, 01:40:22 am »
I overcame this problem by routing out spaces for the joysticks beneath the board.
tcolar
« Reply #3 on: September 25, 2012, 01:47:38 am »
Thanks that helps.
I also have a trackball with mounting plate (3'' suzo/happ) ... is that the same idea that it would be best to use a router to recess it just enough so it can then be flat and covered by the plexy/acrylic ?
I don't actually have a router bu maybe that's an excuse to get one. I do have a dremel tool that has a small router "rig" on it ... not very powerful but that might be good enough to do this job.
mgb
  • North East, US
« Reply #4 on: September 25, 2012, 07:23:19 am »
Yes
  • Last login:Today at 05:49:10 pm
« Reply #5 on: September 25, 2012, 02:57:41 pm »
Worked fine for me.
Protip: It's easier if you use a hole saw or chain drill (a bunch of small holes close together) out the parts that go all the way through.
mcseforsale
  • Creepy Mario Dude
