Author Topic: Linux on a U3100?  (Read 2069 times)
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
Linux on a U3100?
« on: October 10, 2003, 12:30:43 am »
Has anyone had success running Linux on a Wells-Gardner U3100? I tried SuSE with one once but couldn't get it working. My brother keeps bugging me to try Red Hat and XMAME.
"Three warps to the Bugger homeworld"
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
Re:Linux on a U3100?
« Reply #1 on: October 10, 2003, 10:17:31 am »
When it comes to arcade monitors, the important thing is not the OS/software, but rather the actual video card.
The video card is the thing that converts the digital input (PC draw-to-screen comands) to analog output (cable going to your PC monitor or in this case Arcade monitor)
So you need to make sure you use a video card that can output 15kHZ and has linux drivers.
Zapper
« Reply #2 on: October 10, 2003, 06:29:18 pm »
Here's a link to the U3100 info, this model supports VGA/SVGA. Windows 98 runs on it at 640x480 and 800x600 without a problem. My attempt with Linux displayed just fine while booting but when the gui loads it turned into a mess.
Wells-Gardner U3100
IceCold
  • Last login:March 22, 2010, 05:11:22 pm
    • My MAME cabinet webpage
« Reply #3 on: October 11, 2003, 04:45:36 pm »
Wells-Gardner U3100
My guess would be the gui is trying to run at too high of a resolution, but I really don't know.  Sorry I can't help you.
OSCAR
  • Last login:September 06, 2018, 11:31:53 pm
  • I think Bigfoot is blurry, that's the problem...
    • Oscar Controls
« Reply #4 on: October 11, 2003, 04:56:28 pm »
Did you try booting SuSE without starting X, runlevel 2/3 I think?  If it runs fine in non-gui mode, then you should be able to run the SaX2 configuration utility to test X resolutions/graphical modes to figure out if the default resolution is too high like IceCold mentioned.  I think "ctrl" + "alt" + num pad "+" changes the resolution to the next one in your XF86Config file, but I'm not 100% positive.  I'm getting rusty with this stuff since I put SuSE on my Dell laptop.  It installed so perfectly that I didn't have to screw around with things to make them work right (unusual, I know!).
Zapper
« Reply #5 on: October 11, 2003, 10:38:45 pm »
Thanks for the info. I tried Red Hat 9 and it fixed the problem, monitor settings were much easier than in SuSE (at least for a Linux noob like myself). Now I'll give XMAME a try.
